2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Subject: Re: [Merge] ~epics-core/epics-base/+git/Com:thread-join into epics-base:7.0
From: Martin Konrad via Core-talk <[email protected]>
To: mdavidsaver <[email protected]>
Date: Tue, 18 Jun 2019 21:00:17 -0000
The problem I have with this is that
t1.joinWithTimeout(timeout);
// read something modified by t1
is a very common pattern. This is safe because join() acts as a barrier in terms of the memory model. If we proceed without ensuring the thread has shut down we need to ensure we never read/write anything that might be written/read by the thread because we can't be sure t1 has shut down. Otherwise we might have a data race (in other words: anything can happen).
Simple example:
void foo(atomic<bool>& terminate, int& shared) {
  while (!terminate)
    shared = ...;
  atomic<bool> terminate = false;
  int shared;
  thread t1(foo, terminate, shared);
  terminate = true;
} // shared goes out of scope - but foo() might keep writing to it!
It's hard to use this correctly. Should you really implement a joinWithTimeout() I think it should come with a big fat warning in the documentation. I would certainly stay away from doing anything beyond calling "exit" if join times out since I'm pretty sure I wouldn't get it right.
P.S.: I like the idea of leveraging SIGALRM.
https://code.launchpad.net/~epics-core/epics-base/+git/Com/+merge/361379
Your team EPICS Core Developers is subscribed to branch epics-base:7.0.
Re: [Merge] ~epics-core/epics-base/+git/Com:thread-join into epics-base:7.0 J. Lewis Muir via Core-talk
Prev: Re: [Merge] ~epics-core/epics-base/+git/Com:thread-join into epics-base:7.0 Andrew Johnson via Core-talk
Next: Re: [Merge] ~epics-core/epics-base/+git/Com:thread-join into epics-base:7.0 J. Lewis Muir via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
ANJ, 19 Jun 2019 · Home · News · About · Talk · Base · Modules · Extensions ·
