2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Subject: Re: [Merge] ~epics-core/epics-base/+git/Com:thread-join into epics-base:7.0
From: Andrew Johnson via Core-talk <[email protected]>
To: mdavidsaver <[email protected]>
Date: Wed, 19 Jun 2019 16:11:03 -0000
The name epicsThreadMustJoin() would tell someone who knows our other API names that the routine will call cantProceed() if it fails.
I would expect a routine called epicsThreadTryJoin() to be functionally equivalent to the glibc extension pthread_tryjoin_np() that Michael found. It should also be equivalent to passing in a timeout of zero to a timed version.
Might pthreads allow us to write our own equivalent to pthread_timedjoin_np() using waitpid()? I'm hoping for something that might also work on RTEMS-5, MacOS and non-glibc Linux targets...
https://code.launchpad.net/~epics-core/epics-base/+git/Com/+merge/361379
Your team EPICS Core Developers is subscribed to branch epics-base:7.0.
Prev: Re: IOC Threads blocking all signals Michael Davidsaver via Core-talk
Next: Re: IOC Threads blocking all signals William Norum via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Prev: Re: [Merge] ~epics-core/epics-base/+git/Com:thread-join into epics-base:7.0 Ralph Lange via Core-talk
Next: Re: [Merge] ~epics-core/epics-base/+git/Com:thread-join into epics-base:7.0 mdavidsaver via Core-talk
ANJ, 19 Jun 2019 · Home · News · About · Talk · Base · Modules · Extensions ·
