2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Subject: Re: [Merge] ~epics-core/epics-base/+git/Com:thread-join into epics-base:7.0
From: mdavidsaver via Core-talk <[email protected]>
To: mdavidsaver <[email protected]>
Date: Wed, 19 Jun 2019 17:16:26 -0000
> This almost seems too simple...
Unfortunately, yes.  I think this is open to races involving re-use of thread IDs (and maybe use after free?).  This potential is why the RTEMS version uses a barrier to prevent the thread from actually returning until it is joined (the rtems_id stays valid).  Alternately, as with WIN32, allocated a separate epicsThreadId, with a ref. counter, that can outlive the OS task.
https://code.launchpad.net/~epics-core/epics-base/+git/Com/+merge/361379
Your team EPICS Core Developers is subscribed to branch epics-base:7.0.
Prev: Re: [Merge] ~epics-core/epics-base/+git/Com:thread-join into epics-base:7.0 Andrew Johnson via Core-talk
Next: Re: IOC Threads blocking all signals Ralph Lange via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Next: Re: [Merge] ~epics-core/epics-base/+git/Com:thread-join into epics-base:7.0 Andrew Johnson via Core-talk
ANJ, 20 Jun 2019 · Home · News · About · Talk · Base · Modules · Extensions ·
