2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Subject: Re: [Merge] ~anj/epics-base/+git/base-3.15:decimate-filter into epics-base:3.15
From: mdavidsaver via Core-talk <[email protected]>
Date: Tue, 25 Jun 2019 01:42:06 -0000
Review: Needs Fixing
I think the dropped db_field_log are being leaked.  See comments inline.
Diff comments:
> diff --git a/src/std/filters/decimate.c b/src/std/filters/decimate.c
> new file mode 100644
> index 0000000..d34884e
> --- /dev/null
> +++ b/src/std/filters/decimate.c
> @@ -0,0 +1,115 @@
> +* Copyright (c) 2019 UChicago Argonne LLC, as Operator of Argonne
> +*     National Laboratory.
> +* Copyright (c) 2010 Brookhaven National Laboratory.
> +* Copyright (c) 2010 Helmholtz-Zentrum Berlin
> +*     fuer Materialien und Energie GmbH.
> +* EPICS BASE is distributed subject to a Software License Agreement found
> +* in file LICENSE that is included with this distribution.
> + *  Authors: Ralph Lange <[email protected]>,
> + *           Andrew Johnson <[email protected]>
> +#include <stdio.h>
> +#include "freeList.h"
> +#include "db_field_log.h"
> +#include "chfPlugin.h"
> +#include "epicsExport.h"
> +typedef struct myStruct {
> +    epicsInt32 n, i;
> +} myStruct;
> +static void *myStructFreeList;
> +static const
> +chfPluginArgDef opts[] = {
> +    chfInt32(myStruct, n, "n", 1, 0),
> +    chfPluginArgEnd
> +static void * allocPvt(void)
> +    myStruct *my = (myStruct*) freeListCalloc(myStructFreeList);
> +    return (void *) my;
> +static void freePvt(void *pvt)
> +    freeListFree(myStructFreeList, pvt);
> +static int parse_ok(void *pvt)
> +    myStruct *my = (myStruct*) pvt;
> +    if (my->n < 1)
> +        return -1;
> +    return 0;
> +static db_field_log* filter(void* pvt, dbChannel *chan, db_field_log *pfl) {
> +    db_field_log *passfl = NULL;
> +    epicsInt32 i = my->i;
> +    if (pfl->ctx == dbfl_context_read)
> +        return pfl;
> +    if (i++ == 0)
> +        passfl = pfl;
> +    if (i >= my->n)
> +        i = 0;
> +    my->i = i;
> +    return passfl;
Should db_delete_field_log() be called if the entry is being dropped?  (cf. dbnd.c)
> +static void channelRegisterPre(dbChannel *chan, void *pvt,
> +                               chPostEventFunc **cb_out, void **arg_out, db_field_log *probe)
> +    *cb_out = filter;
> +    *arg_out = pvt;
> +static void channel_report(dbChannel *chan, void *pvt, int level, const unsigned short indent)
> +    printf("%*sDecimate (dec): n=%d, i=%d\n", indent, "",
> +           my->n, my->i);
> +static chfPluginIf pif = {
> +    allocPvt,
> +    freePvt,
> +    NULL, /* parse_error, */
> +    parse_ok,
> +    NULL, /* channel_open, */
> +    channelRegisterPre,
> +    NULL, /* channelRegisterPost, */
> +    channel_report,
> +    NULL /* channel_close */
> +static void decInitialize(void)
> +    static int firstTime = 1;
> +    if (!firstTime) return;
> +    firstTime = 0;
> +    if (!myStructFreeList)
> +        freeListInitPvt(&myStructFreeList, sizeof(myStruct), 64);
> +    chfPluginRegister("dec", &pif, opts);
> +epicsExportRegistrar(decInitialize);
> diff --git a/src/std/filters/test/decTest.c b/src/std/filters/test/decTest.c
> index 0000000..cc9317e
> --- /dev/null
> +++ b/src/std/filters/test/decTest.c
> @@ -0,0 +1,273 @@
> +#include <string.h>
> +#include "dbStaticLib.h"
> +#include "dbAccessDefs.h"
> +#include "dbCommon.h"
> +#include "dbChannel.h"
> +#include "registry.h"
> +#include "errlog.h"
> +#include "dbmf.h"
> +#include "epicsUnitTest.h"
> +#include "dbUnitTest.h"
> +#include "epicsTime.h"
> +#include "testMain.h"
> +#include "osiFileName.h"
> +void filterTest_registerRecordDeviceDriver(struct dbBase *);
The testing here seems a bit too nuts and bolts in not calling dbChannelOpen() and using dbChannelRunPreChain().  Which may be obscuring the fact that the plugin itself should be db_delete_field_log() the entries which it drops.
> +static int fl_equal(const db_field_log *pfl1, const db_field_log *pfl2) {
> +    return !(memcmp(pfl1, pfl2, sizeof(db_field_log)));
> +static void fl_setup(dbChannel *chan, db_field_log *pfl, long val) {
> +    struct dbCommon  *prec = dbChannelRecord(chan);
> +    pfl->ctx  = dbfl_context_event;
> +    pfl->type = dbfl_type_val;
> +    pfl->stat = prec->stat;
> +    pfl->sevr = prec->sevr;
> +    pfl->time = prec->time;
> +    pfl->field_type  = DBF_LONG;
> +    pfl->no_elements = 1;
> +     * use memcpy to avoid a bus error on
> +     * union copy of char in the db at an odd
> +     * address
> +    memcpy(&pfl->u.v.field,
> +           dbChannelField(chan),
> +           dbChannelFieldSize(chan));
> +    pfl->u.v.field.dbf_long = val;
> +static void testHead (char* title) {
> +    testDiag("--------------------------------------------------------");
> +    testDiag("%s", title);
> +static void mustDrop(dbChannel *pch, db_field_log *pfl, char* m) {
> +    db_field_log *pfl2 = dbChannelRunPreChain(pch, pfl);
> +    testOk(NULL == pfl2, "filter drops field_log (%s)", m);
> +static void mustPass(dbChannel *pch, db_field_log *pfl, char* m) {
> +    testOk(pfl == pfl2, "filter passes field_log (%s)", m);
> +static void checkAndOpenChannel(dbChannel *pch, const chFilterPlugin *plug) {
> +    ELLNODE *node;
> +    chFilter *filter;
> +    chPostEventFunc *cb_out = NULL;
> +    void *arg_out = NULL;
> +    db_field_log fl, fl1;
> +    testDiag("Test filter structure and open channel");
> +    testOk((ellCount(&pch->filters) == 1), "channel has one plugin");
> +    fl_setup(pch, &fl, 1);
> +    fl1 = fl;
> +    node = ellFirst(&pch->filters);
> +    filter = CONTAINER(node, chFilter, list_node);
> +    plug->fif->channel_register_pre(filter, &cb_out, &arg_out, &fl1);
> +    testOk(cb_out && arg_out,
> +        "register_pre registers one filter with argument");
> +    testOk(fl_equal(&fl1, &fl),
> +        "register_pre does not change field_log data type");
> +    testOk(!(dbChannelOpen(pch)), "dbChannel with plugin dec opened");
> +    node = ellFirst(&pch->pre_chain);
> +    filter = CONTAINER(node, chFilter, pre_node);
> +    testOk((ellCount(&pch->pre_chain) == 1 && filter->pre_arg != NULL),
> +        "dec has one filter with argument in pre chain");
> +    testOk((ellCount(&pch->post_chain) == 0),
> +        "sync has no filter in post chain");
> +MAIN(decTest)
> +    dbChannel *pch;
> +    const chFilterPlugin *plug;
> +    char myname[] = "dec";
> +    db_field_log *pfl[10];
> +    int i;
> +    dbEventCtx evtctx;
> +    testPlan(68);
> +    testdbPrepare();
> +    testdbReadDatabase("filterTest.dbd", NULL, NULL);
> +    filterTest_registerRecordDeviceDriver(pdbbase);
> +    testdbReadDatabase("xRecord.db", NULL, NULL);
> +    eltc(0);
> +    testIocInitOk();
> +    eltc(1);
> +    evtctx = db_init_events();
> +    testOk(!!(plug = dbFindFilter(myname, strlen(myname))),
> +        "plugin '%s' registered correctly", myname);
> +    /* N < 1 */
> +    testOk(!(pch = dbChannelCreate("x.VAL{\"dec\":{\"n\":-1}}")),
> +           "dbChannel with dec (n=-1) failed");
> +    testOk(!(pch = dbChannelCreate("x.VAL{\"dec\":{\"n\":0}}")),
> +           "dbChannel with dec (n=0) failed");
> +    /* Bad parms */
> +    testOk(!(pch = dbChannelCreate("x.VAL{\"dec\":{}}")),
> +           "dbChannel with dec (no parm) failed");
> +    testOk(!(pch = dbChannelCreate("x.VAL{\"dec\":{\"x\":true}}")),
> +           "dbChannel with dec (x=true) failed");
> +    /* No Decimation (N=1) */
> +    testHead("No Decimation (n=1)");
> +    testOk(!!(pch = dbChannelCreate("x.VAL{\"dec\":{\"n\":1}}")),
> +           "dbChannel with plugin dec (n=1) created");
> +    checkAndOpenChannel(pch, plug);
> +    for (i = 0; i < 5; i++) {
> +        pfl[i] = db_create_read_log(pch);
> +        fl_setup(pch, pfl[i], 10 + i);
> +    testDiag("Test event stream");
> +    mustPass(pch, pfl[0], "i=0");
> +    mustPass(pch, pfl[1], "i=1");
> +    mustPass(pch, pfl[2], "i=2");
> +    mustPass(pch, pfl[3], "i=3");
> +    mustPass(pch, pfl[4], "i=4");
> +        db_delete_field_log(pfl[i]);
> +    dbChannelDelete(pch);
> +    /* Decimation (N=2) */
> +    testHead("Decimation (n=2)");
> +    testOk(!!(pch = dbChannelCreate("x.VAL{\"dec\":{\"n\":2}}")),
> +           "dbChannel with plugin dec (n=2) created");
> +    for (i = 0; i < 10; i++) {
> +        fl_setup(pch, pfl[i], 20 + i);
> +    mustDrop(pch, pfl[1], "i=1");
> +    mustDrop(pch, pfl[3], "i=3");
> +    mustDrop(pch, pfl[5], "i=5");
> +    mustPass(pch, pfl[6], "i=6");
> +    mustDrop(pch, pfl[7], "i=7");
> +    mustPass(pch, pfl[8], "i=8");
> +    mustDrop(pch, pfl[9], "i=9");
> +    /* Decimation (N=3) */
> +    testHead("Decimation (n=3)");
> +    testOk(!!(pch = dbChannelCreate("x.VAL{\"dec\":{\"n\":3}}")),
> +           "dbChannel with plugin dec (n=3) created");
> +        fl_setup(pch, pfl[i], 30 + i);
> +    mustDrop(pch, pfl[2], "i=2");
> +    mustDrop(pch, pfl[4], "i=4");
> +    mustDrop(pch, pfl[8], "i=8");
> +    mustPass(pch, pfl[9], "i=9");
> +    /* Decimation (N=4) */
> +    testHead("Decimation (n=4)");
> +    testOk(!!(pch = dbChannelCreate("x.VAL{\"dec\":{\"n\":4}}")),
> +           "dbChannel with plugin dec (n=4) created");
> +        fl_setup(pch, pfl[i], 40 + i);
> +    mustDrop(pch, pfl[6], "i=6");
> +    db_close_events(evtctx);
> +    testIocShutdownOk();
> +    testdbCleanup();
> +    return testDone();
https://code.launchpad.net/~anj/epics-base/+git/base-3.15/+merge/368347
Your team EPICS Core Developers is subscribed to branch epics-base:3.15.
[Merge] ~anj/epics-base/+git/base-3.15:decimate-filter into epics-base:3.15 Andrew Johnson via Core-talk
Prev: [Merge] ~info-martin-konrad/epics-base:fix-compiler-warnings into epics-base:3.15 noreply--- via Core-talk
Next: Re: [Merge] ~info-martin-konrad/epics-base:clean-up-msi into epics-base:3.15 mdavidsaver via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Prev: [Merge] ~anj/epics-base/+git/base-3.15:decimate-filter into epics-base:3.15 Andrew Johnson via Core-talk
Next: Re: [Merge] ~anj/epics-base/+git/base-3.15:decimate-filter into epics-base:3.15 Andrew Johnson via Core-talk
ANJ, 25 Jun 2019 · Home · News · About · Talk · Base · Modules · Extensions ·
