2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Subject: Re: [Merge] ~dirk.zimoch/epics-base:vxWorks5 into epics-base:7.0
From: Andrew Johnson via Core-talk <[email protected]>
To: [email protected]
Date: Tue, 25 Jun 2019 14:39:16 -0000
Review: Disapprove
We think the best way to suppress building a particular module is to filter out the target from the CROSS_COMPILER_TARGET_ARCHS inside the the module's configure/CONFIG_SITE (or a .local version of that) file.
However we're not going to re-add the template instances to the EPICS 7 tree, so you're going to have to maintain local patches if you want this.
- Core meeting
https://code.launchpad.net/~dirk.zimoch/epics-base/+git/epics-base/+merge/355587
Your team EPICS Core Developers is subscribed to branch epics-base:7.0.
Prev: Re: [Merge] ~info-martin-konrad/epics-base:fix-substitution-file-expansion into epics-base:3.15 Andrew Johnson via Core-talk
Next: [Merge] ~dirk.zimoch/epics-base:vxWorks5 into epics-base:7.0 Andrew Johnson via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Prev: [Merge] ~info-martin-konrad/epics-base:fix-substitution-file-expansion into epics-base:3.15 noreply--- via Core-talk
ANJ, 26 Jun 2019 · Home · News · About · Talk · Base · Modules · Extensions ·
