2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Subject: Re: [Merge] ~epics-core/epics-base/+git/Com:thread-join into epics-base:7.0
From: mdavidsaver via Core-talk <[email protected]>
To: mdavidsaver <[email protected]>
Date: Sun, 30 Jun 2019 20:38:25 -0000
Review: Approve
Thanks Andrew.
> IOC now requires EPICS_THREAD_CAN_JOIN=1
Do you see tests failing with this change?  If I was careful, then they shouldn't.  The change should only result in transient resource leaks triggering false positives on a hypothetical target with EPICS_THREAD_CAN_JOIN=0 and valgrind support.
That said, I'm happy to be rid of EPICS_THREAD_CAN_JOIN.
> The RTEMS and Windows implementations could probably do the same thing.
I've no objection to this, but I'm not motivated to do this myself.
> ... EPICS_THREAD_OPTS_INIT ...
Also no objection.
https://code.launchpad.net/~epics-core/epics-base/+git/Com/+merge/361379
Your team EPICS Core Developers is subscribed to branch epics-base:7.0.
Prev: RE: Crash in pvData Mark Rivers via Core-talk
Next: Why is EpicsHostArch.pl not executable? Konrad, Martin via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Prev: Re: [Merge] ~epics-core/epics-base/+git/Com:thread-join into epics-base:7.0 Andrew Johnson via Core-talk
Next: Re: [Merge] ~epics-core/epics-base/+git/Com:thread-join into epics-base:7.0 Andrew Johnson via Core-talk
ANJ, 02 Jul 2019 · Home · News · About · Talk · Base · Modules · Extensions ·
