2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Subject: Re: socket shutdown races?
From: Michael Davidsaver via Core-talk <[email protected]>
To: EPICS core-talk <[email protected]>
Date: Tue, 9 Jul 2019 16:50:47 -0700
On 7/8/19 8:05 PM, Michael Davidsaver wrote:
> Sorry for the stream of consciousness (aka ramble).  I've been digging into
> this all day.  I thought I'd see if anyone else has run across
> this situation before.
part 2?
I did an experiment on interrupting recvfrom() on a UDP socket.
Also accept() or recv() with a TCP socket.  Used travis-ci VM for Linux
and OSX.  Appveyor VM for windows.
TCP recv()
Linux - shutdown(SHUT_RDWR) returns 0 and interrupts.  recv() returns 0.
OSX - same as Linux
Windows - shutdown(SHUT_RDWR) returns 0 and interrupts!  recv() returns WinError 10038 (not a socket)
So for the case which really matters, shutdown() appears to work on all three.  (also RTEMS and presumably vxworks)
bye bye epicsSocketSystemCallInterruptMechanismQuery() ?
TCP accept()
Linux - shutdown(SHUT_RDWR) returns 0 and interrupts.  accept() returns EINVAL
OSX - shutdown() errors and does not interrupt.  close() interrupts.  accept() returns EBADR
Windows - shutdown() errors and does not interrupt.  close() interrupts.  accept() returns WinError 10038 (not a socket)
UDP recvfrom()
Linux - shutdown(SHUT_RDWR) returns 0 and interrupts.  recvfrom() returns 0 (ambiguous w/ valid UDP zero length packet)
OSX - shutdown() errors and does not interrupt.  close() interrupts, and recvfrom() returns EBADF
Windows - shutdown() succeeds and interrupts.  recvfrom() returns WinError 10022 (invalid argument)
socket shutdown races? Michael Davidsaver via Core-talk
Prev: Re: [Merge] ~epics-core/epics-base/+git/Com:make-simple into epics-base:7.0 Andrew Johnson via Core-talk
Next: Re: [Merge] ~epics-core/epics-base/+git/Com:make-simple into epics-base:7.0 mdavidsaver via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Prev: socket shutdown races? Michael Davidsaver via Core-talk
Next: Build failed: epics-base base-integration-267 AppVeyor via Core-talk
ANJ, 10 Jul 2019 · Home · News · About · Talk · Base · Modules · Extensions ·
