2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Subject: Re: epicsThreadOnceTest/epicsThreadPriorityTest failures
From: Heinz Junkes via Core-talk <[email protected]>
To: Michael Davidsaver <[email protected]>
Cc: EPICS core-talk <[email protected]>
Date: Thu, 18 Jul 2019 09:47:40 +0200
Michael,
is this RTEMS related?
When I started trying to use RTEMS5 with osd/posix I was confronted with exactly this problem.
epicsThreadOnce and epicsThreadPriority issues.
I developed a lot of "cramp constructions" to make it work.
Then Till had built in a modification for "non-epicsThreads may receive wrong priority and crash” (https://bugs.launchpad.net/epics-base/+bug/1816841)
affecting SCHED_FIFO? and my problems with RTEMS were solved with it and I could take away my messed up modifications.
Since then I had no stress anymore with that.
Heinz
> On 17. Jul 2019, at 20:32, Michael Davidsaver via Core-talk <[email protected]> wrote:
> I can't recall seeing failures in epicsThreadOnceTest or epicsThreadPriorityTest before...
> On 7/17/19 11:27 AM, APS Jenkins via Core-talk wrote:
>> Test Summary Report
>> epicsMathTest.tap          (Wstat: 0 Tests: 35 Failed: 0)
>>  TODO passed:   8-9, 11-12, 22-23
>> epicsThreadOnceTest.tap    (Wstat: 0 Tests: 11 Failed: 2)
>>  Failed tests:  1, 8
>> epicsThreadPriorityTest.tap (Wstat: 0 Tests: 5 Failed: 1)
>>  Failed test:  3
>>  Parse errors: Bad plan.  You planned 7 tests but ran 5.
>> ipAddrToAsciiTest.tap      (Wstat: 0 Tests: 5 Failed: 1)
>>  Failed test:  2
>> Files=39, Tests=2898,  5 wallclock secs ( 0.61 usr +  0.70 sys =  1.31 CPU)
>> Result: FAIL
Attachment: smime.p7s
Description: S/MIME cryptographic signature
Re: epicsThreadOnceTest/epicsThreadPriorityTest failures Johnson, Andrew N. via Core-talk
Build failed in Jenkins: epics-base-3.15-win64-test #234 APS Jenkins via Core-talk
epicsThreadOnceTest/epicsThreadPriorityTest failures Michael Davidsaver via Core-talk
Prev: Build failed in Jenkins: epics-base-3.15-win32s-test #232 APS Jenkins via Core-talk
Next: Jenkins build is back to normal : epics-base-3.15-win32s-test #233 APS Jenkins via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Prev: epicsThreadOnceTest/epicsThreadPriorityTest failures Michael Davidsaver via Core-talk
Next: Re: epicsThreadOnceTest/epicsThreadPriorityTest failures Johnson, Andrew N. via Core-talk
ANJ, 18 Jul 2019 · Home · News · About · Talk · Base · Modules · Extensions ·
