2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Subject: Re: EPICS 7 array link inconsistencies
From: "Johnson, Andrew N. via Core-talk" <[email protected]>
Date: Wed, 24 Jul 2019 19:33:19 +0000
Hi Dirk,
On 7/24/19 7:04 AM, Zimoch Dirk (PSI) via Core-talk wrote:
I found something confusing in the link syntax today when accessing arrays.
field(INP, "$(WF_RECORD).[5] CP") returns the number at index 5
but field(INP, "$(WF_RECORD).[5]") returns the number at index 0
This can be very confusing to the user. It would be nice to have the same array
syntax regardless of the link type, CA or not.
DB links do not currently support server-side filters, we never added them although it should be possible. Your .[5] is inserting an array filter into the CA channel used for the CA link, whereas the DB link is ignoring that filter spec (maybe the IOC should show a warning message if someone tries that).
If you wanted to take this on as a project I'd be happy to see it worked on. You would have to change the internals of the DB link to use a dbChannel instead of the current DBADDR, replacing calls to dbNameToAddr() with dbChannelCreate() and dbChannelOpen(). If a link's channel has any filters the dbDbGetValue() routine would have to call the dbChannelRunPreChain() and dbChannelRunPostChain() routines to execute them, and that would require creating a db_field_log to describe the source data for the filters to process.
If there are no filters you should short-circuit the new process and just use the existing approach, which will be much faster. I haven't thought about the other dbDbGet...() routines or how the dbDb_lset::doLocked() method might affect the above process — you'd want to only run the filter chain once if possible in this case; take a look at how the soft device support routines use dbLinkDoLocked() to fetch a value and timestamp through a link atomically in recent releases to understand how this method is used.
If you do decide to try this please let us know.
- Andrew
Complexity comes for free, Simplicity you have to work for.
Re: EPICS 7 array link inconsistencies Zimoch Dirk (PSI) via Core-talk
Prev: Jenkins build became unstable: epics-pva2pva-linux32 #126 APS Jenkins via Core-talk
Next: Re: Misleading "initPeriodic: Scan rate ... is not achievable" and sleep quantum implementation Johnson, Andrew N. via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Prev: EPICS 7 array link inconsistencies Zimoch Dirk (PSI) via Core-talk
Next: Re: EPICS 7 array link inconsistencies Zimoch Dirk (PSI) via Core-talk
ANJ, 26 Jul 2019 · Home · News · About · Talk · Base · Modules · Extensions ·
