2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Subject: Re: [Merge] ~info-martin-konrad/epics-base:clean-up-msi into epics-base:3.15
From: Andrew Johnson via Core-talk <[email protected]>
To: [email protected]
Date: Thu, 25 Jul 2019 19:32:30 -0000
While merging 3.15 up to the 7.0 branch I noticed that Martin removed the inclusion of errlog.h and the call to errlogFlush() at the end of the main() routine. While there are no calls to errlog routines in the msi.cpp file, the macLib routines *do* call errlogPrintf() in the event that errors are detected, so the errlogFlush() is still necessary. I will restore it.
https://code.launchpad.net/~info-martin-konrad/epics-base/+git/epics-base/+merge/361502
Your team EPICS Core Developers is subscribed to branch epics-base:3.15.
Prev: Build failed: epics-base base-7.0-277 AppVeyor via Core-talk
Next: Jenkins build became unstable: epics-base-3.15-test #123 APS Jenkins via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Prev: [Merge] ~info-martin-konrad/epics-base:clean-up-msi into epics-base:3.15 noreply--- via Core-talk
Next: IETF note on invalid IP names White, Greg via Core-talk
ANJ, 25 Jul 2019 · Home · News · About · Talk · Base · Modules · Extensions ·
