2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Subject: normativeTypes module in EPICS 7.0.3
From: "Johnson, Andrew N. via Core-talk" <[email protected]>
To: 'Bruno Martins' <[email protected]>
Cc: EPICS core-talk <[email protected]>
Date: Fri, 26 Jul 2019 19:05:34 +0000
Hi Bruno,
I'm currently working on generating a new EPICS release, and I just noticed that there is nothing in the normativeTypes Release Notes document about all of the updates you made to the validation code back in May and June. Would you have any time in the next working day or so to add some notes about your changes to the top of the documentation/RELEASE_NOTES.md file?
I will need to bump the module's version number from 5.2.2; after your changes, should this become 6.0.0 or would 5.3.0 be a better choice? You could just answer that question in Release notes heading you use if you like.
I suspect the file documentation/ntCPP.html may also need some changes to match your updates. I'm not expecting you to work on that at the same time, but I'd appreciate if you could take a quick look at it and assess how much it might need to be modified. If the changes are trivial and you can do them that would be great, but if not please just include a comment in the Release Notes that the other document has not been updated yet (it already shows an older version and date).
Sorry this request is a bit last-minute.
- Andrew
Complexity comes for free, Simplicity you have to work for.
Re: normativeTypes module in EPICS 7.0.3 Bruno Martins via Core-talk
Prev: Re: EPICS 7 array link inconsistencies Zimoch Dirk (PSI) via Core-talk
Next: Re: epics base compilation for ARM Cotex-A53 (ARM64bit) Johnson, Andrew N. via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Prev: [Bug 1392516] Re: OSI monotonic time source Andrew Johnson via Core-talk
Next: Re: normativeTypes module in EPICS 7.0.3 Bruno Martins via Core-talk
ANJ, 26 Jul 2019 · Home · News · About · Talk · Base · Modules · Extensions ·
