2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Subject: Re: [Merge] ~epics-core/epics-base/+git/Com:use-monotonic into epics-base:7.0
From: "Johnson, Andrew N. via Core-talk" <[email protected]>
To: "[email protected]" <[email protected]>, "EPICS core-talk" <[email protected]>
Date: Fri, 23 Aug 2019 21:12:15 +0000
Attaching graph as described.
On 8/23/19 4:07 PM, Andrew Johnson wrote:
The drift of the 1-second scan thread on Linux has disappeared since the change (in 7.0.x) from CLOCK_MONOTONIC_RAW to CLOCK_MONOTONIC. I will send a graph showing my measurements to core-talk.
Complexity comes for free, Simplicity you have to work for.
Attachment: lp-361380-drift.svg
Description: lp-361380-drift.svg
Re: [Merge] ~epics-core/epics-base/+git/Com:use-monotonic into epics-base:7.0 Andrew Johnson via Core-talk
Prev: Re: [Merge] ~epics-core/epics-base/+git/Com:use-monotonic into epics-base:7.0 Andrew Johnson via Core-talk
Next: Re: [Merge] ~epics-core/epics-base/+git/Com:make-simple into epics-base:7.0 Andrew Johnson via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Next: Re: [Merge] ~epics-core/epics-base/+git/Com:timeopt into epics-base:7.0 Andrew Johnson via Core-talk
ANJ, 23 Aug 2019 · Home · News · About · Talk · Base · Modules · Extensions ·
