2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Subject: [Bug 1841608] Re: logClient falsely sends error logs on all connections
From: Dirk Zimoch via Core-talk <[email protected]>
To: [email protected]
Date: Tue, 27 Aug 2019 14:48:27 -0000
I will probably push a branch soon which addresses other problems with
logClient.
You received this bug notification because you are a member of EPICS
Core Developers, which is subscribed to EPICS Base.
Matching subscriptions: epics-core-list-subscription
https://bugs.launchpad.net/bugs/1841608
Title:
Status in EPICS Base:
  New
Bug description:
  Error messages generated with errlog and friends are sent to all logClients. This is wrong.
  For example caPutLog uses the logClient facility. Its output to a log server should not be mixed with errlogs.
  This bug had been introduced in commit ac2ff29a.
  The fix moves errlog listener connection back from logClient to
  iocLog.
To manage notifications about this bug go to:
https://bugs.launchpad.net/epics-base/+bug/1841608/+subscriptions
[Bug 1841608] [NEW] logClient falsely sends error logs on all connections Dirk Zimoch via Core-talk
Prev: [Bug 1841608] [NEW] logClient falsely sends error logs on all connections Dirk Zimoch via Core-talk
Next: [Bug 1841634] [NEW] CP link triggers lost when record is async Andrew Johnson via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Next: [Bug 1841608] Re: logClient falsely sends error logs on all connections Dirk Zimoch via Core-talk
ANJ, 30 Aug 2019 · Home · News · About · Talk · Base · Modules · Extensions ·
