2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Subject: [Bug 1841692] Re: Non-VME RTEMS targets should define pdevLibVME
From: mdavidsaver via Core-talk <[email protected]>
To: [email protected]
Date: Wed, 28 Aug 2019 02:21:29 -0000
Nope.  I was of the same mind.
https://github.com/epics-
modules/devlib2/blob/38c3e3ebc8ff34cff37b9acd905a270507263ea1/vmeApp/os/RTEMS/devLibVMEOSD.c#L354-L358
You received this bug notification because you are a member of EPICS
Core Developers, which is subscribed to EPICS Base.
Matching subscriptions: epics-core-list-subscription
https://bugs.launchpad.net/bugs/1841692
Title:
Status in EPICS Base:
  In Progress
Status in EPICS Base 7.0 series:
  In Progress
Bug description:
  Support modules that build IOCs with drivers that call devLib routines
  can't be compiled on non-VME RTEMS targets such as RTEMS-pc386 since
  the linker fails to find the symbol pdevLibVME. The build *only* fails
  for RTEMS targets though, other non-VME targets such as Windows or
  darwin will quite happily compile and link the IOC code. This makes
  the authors of support modules have to jump through hoops to ensure
  they don't build IOCs for targets that will fail, or to just let the
  build fail (many sites don't build for RTEMS anyway).
  The RTEMS implementation of devLibVMEOSD.c uses pre-processor
  conditionals to only define the devLibVME *pdevLibVME pointer inside
  #if defined(__PPC__) || defined(__mcf528x__)
  We could make life much easier for module authors by adding this:
  diff --git a/modules/libcom/src/osi/os/RTEMS/devLibVMEOSD.c b/modules/libcom/src/osi/os/RTEMS/devLibVMEOSD.c
  index 0a96bad..b8f79e7 100644
  --- a/modules/libcom/src/osi/os/RTEMS/devLibVMEOSD.c
  +++ b/modules/libcom/src/osi/os/RTEMS/devLibVMEOSD.c
  @@ -350,7 +350,12 @@ static void unsolicitedHandlerEPICS(int vectorNumber)
  -#endif /* defined(__PPC__) && defined(mpc750) */
  +#else /* !defined(__PPC__) && !defined(__mcf528x__) */
  +/* No known VME interface here, provide a dummy */
  +devLibVME *pdevLibVME;
  +#endif /* defined(__PPC__) || defined(__mcf528x__) */
    * Some vxWorks convenience routines
  With that change (which is identical to the osi/os/default version),
  the non-VME RTEMS targets will build exactly the same as the
  workstation OS targets; an IOC that calls devLib will now compile,
  although it obviously won't actually work if booted.
  Any objections?
To manage notifications about this bug go to:
https://bugs.launchpad.net/epics-base/+bug/1841692/+subscriptions
[Bug 1841692] [NEW] Non-VME RTEMS targets should define pdevLibVME Andrew Johnson via Core-talk
Prev: [Bug 1841692] [NEW] Non-VME RTEMS targets should define pdevLibVME Andrew Johnson via Core-talk
Next: [Bug 1841692] Re: Non-VME RTEMS targets should define pdevLibVME Andrew Johnson via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
ANJ, 28 Aug 2019 · Home · News · About · Talk · Base · Modules · Extensions ·
