2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Subject: Runtime slowness in CSS 3.2.16 to CSS 4.5.0 OPI project migration
From: Lopez Antonio Miguel via Core-talk <[email protected]>
Date: Tue, 3 Sep 2019 11:44:16 +0000
Hi to all!,
I'm involved on a OPI migration from CSS 3.2.16 to 4.5.0 version. This OPI set was originally developed on CSS 3.2.16, and has been growing and growing for years to the point that the performance of the OPI set is really low. I mention OPI set because the architecture is based on various panels that are linked through linking containers and macros to a bigger main OPI that contains tabbed panels depending of the system you want to control.
The main problem I'm having is the delay I'm getting when I try to open the main OPIs (the ones with the bunch linking containers) with CSS 4.5.0, even with half of the original panels. For example, a main OPI that usually takes 2 minutes after opening it to be usable in 3.2.16, takes about 5 minutes to open in 4.5.0.
In contrast, once the OPI is opened and is usable, the use of CPU in 4.5.0 remains almost constant in 7-8%, which is good, because in 3.2.16 the constant use of CPU was around 60-70%, the behavior we wanted to avoid with this migration…
Does anyone have any ideas or tests I can do to avoid this slowness when opening or refreshing the OPIs in 4.5.0?
Thanks in advance!
A. Miguel
Prev: Help Basawashri Biradar via Core-talk
Next: Build failed: EPICS Base base-7.0-425 AppVeyor via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Help J. Lewis Muir via Core-talk
Next: Re: Runtime slowness in CSS 3.2.16 to CSS 4.5.0 OPI project migration Kasemir, Kay via Core-talk
ANJ, 03 Sep 2019 · Home · News · About · Talk · Base · Modules · Extensions ·
