2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Subject: Build failed in Jenkins: epics-base-3.15-linux32-test #218
From: APS Jenkins via Core-talk <[email protected]>
To: [email protected]
Date: Fri, 6 Sep 2019 03:45:44 -0500 (CDT)
See <https://jenkins.aps.anl.gov/job/epics-base-3.15-linux32-test/218/display/redirect>
Changes:
Started by upstream project "epics-base-3.15-linux32" build number 403
originally caused by:
 Started by upstream project "epics-base-3.15" build number 436
  Started by user Andrew Johnson
Running as SYSTEM
[EnvInject] - Loading node environment variables.
Building remotely on linux32-uranus (linux32) in workspace <https://jenkins.aps.anl.gov/job/epics-base-3.15-linux32-test/ws/>
[epics-base-3.15-linux32] $ /bin/sh -xe /tmp/jenkins5691003472321982545.sh
+ make -s clean-tests
+ make -j4 --no-print-directory tapfiles CROSS_COMPILER_TARGET_ARCHS=
make -C ./configure tapfiles
make -C O.linux-x86 -f ../Makefile TOP=../.. \
    T_A=linux-x86 tapfiles
make[2]: Nothing to be done for 'tapfiles'.
make -C ./src tapfiles
make -C ./tools tapfiles
make -C O.linux-x86 -f ../Makefile TOP=../../.. \
make[3]: Nothing to be done for 'tapfiles'.
make -C tools/test tapfiles
make -C template/base tapfiles
make -C template/ext tapfiles
make -C ./libCom tapfiles
make -C O.linux-x86 -f ../Makefile TOP=../../../.. \
perl -CSD Breaktable.t -tap > Breaktable.tap
perl -CSD DBD.t -tap > DBD.tap
perl -CSD Device.t -tap > Device.tap
perl -CSD Driver.t -tap > Driver.tap
perl -CSD Function.t -tap > Function.tap
perl -CSD macLib.t -tap > macLib.tap
perl -CSD Menu.t -tap > Menu.tap
perl -CSD Recfield.t -tap > Recfield.tap
perl -CSD Recordtype.t -tap > Recordtype.tap
#   Failed test 'C declaration'
#   at Menu.t line 26.
#                   '#ifndef test_NUM_CHOICES
# typedef enum {
#     ch1                             /* Choice 1 */,
#     ch2                             /* Choice 2 */
# } test;
# #define test_NUM_CHOICES 2
# #endif
#     doesn't match '(?x-ism: ^
#     \s* typedef \s+ enum \s+ \{ \s* \n
#     \s*     ch1 \s+ /\* [^*]* \*/, \s* \n
#     \s*     ch2 \s+ /\* [^*]* \*/ \s* \n
#     \s* \} \s* test \s* ; \s* \n
#     \s* \# \s* define \s+ test_NUM_CHOICES \s+ 2 \s* \n
#     \s* $ )'
# Looks like you failed 1 test of 14.
../../../../configure/RULES_BUILD:375: recipe for target 'Menu.tap' failed
make[3]: [Menu.tap] Error 1 (ignored)
perl -CSD Registrar.t -tap > Registrar.tap
perl -CSD Snippets.t -tap > Snippets.tap
perl -CSD Variable.t -tap > Variable.tap
make -C libCom/RTEMS tapfiles
make -C ca/client tapfiles
make -C libCom/test tapfiles
make -C ca/client/tools tapfiles
make -C ca/legacy/gdd tapfiles
make -C ./ioc tapfiles
make -C O.linux-x86 -f ../Makefile TOP=../../../../.. \
perl -CSD epicsUnitTestTest.t -tap > epicsUnitTestTest.tap
make -C ca/client/perl tapfiles
perl -CSD epicsTypesTest.t -tap > epicsTypesTest.tap
make -C ca/legacy/pcas tapfiles
perl -CSD epicsInlineTest.t -tap > epicsInlineTest.tap
perl -CSD epicsCalcTest.t -tap > epicsCalcTest.tap
make -C ./build tapfiles
perl -CSD epicsAlgorithmTest.t -tap > epicsAlgorithmTest.tap
perl -CSD epicsMathTest.t -tap > epicsMathTest.tap
make -C O.linux-x86 -f ../Makefile TOP=../../../../../.. \
perl -CSD epicsMMIOTest.t -tap > epicsMMIOTest.tap
perl -CSD epicsEllTest.t -tap > epicsEllTest.tap
perl -CSD epicsEnvTest.t -tap > epicsEnvTest.tap
perl -CSD epicsEnvUnsetTest.t -tap > epicsEnvUnsetTest.tap
perl -CSD epicsErrlogTest.t -tap > epicsErrlogTest.tap
perl -CSD epicsStdioTest.t -tap > epicsStdioTest.tap
make[4]: Nothing to be done for 'tapfiles'.
make -C ./example tapfiles
perl -CSD epicsStdlibTest.t -tap > epicsStdlibTest.tap
make -C ./directoryService tapfiles
perl -CSD epicsSockResolveTest.t -tap > epicsSockResolveTest.tap
perl -CSD epicsStringTest.t -tap > epicsStringTest.tap
perl -CSD epicsTimeTest.t -tap > epicsTimeTest.tap
make -C O.linux-x86 -f ../Makefile TOP=../../../../../../.. \
make[5]: Nothing to be done for 'tapfiles'.
perl -CSD epicsTimeZoneTest.t -tap > epicsTimeZoneTest.tap
perl -CSD epicsThreadTest.t -tap > epicsThreadTest.tap
perl -CSD epicsThreadOnceTest.t -tap > epicsThreadOnceTest.tap
log client: connected to log server at "127.0.0.1:36194"
make -C ca/legacy/pcas/ex tapfiles
perl -CSD epicsThreadPriorityTest.t -tap > epicsThreadPriorityTest.tap
perl -CSD epicsThreadPrivateTest.t -tap > epicsThreadPrivateTest.tap
make -C ioc/db/test tapfiles
perl -CSD epicsThreadHooksTest.t -tap > epicsThreadHooksTest.tap
perl -CSD dbShutdownTest.t -tap > dbShutdownTest.tap
perl -CSD dbPutLinkTest.t -tap > dbPutLinkTest.tap
make -C ioc/dbtemplate/test tapfiles
perl -CSD msi.t -tap > msi.tap
perl -CSD epicsThreadPoolTest.t -tap > epicsThreadPoolTest.tap
perl -CSD dbLockTest.t -tap > dbLockTest.tap
perl -CSD testdbConvert.t -tap > testdbConvert.tap
make -C ./std tapfiles
perl -CSD callbackTest.t -tap > callbackTest.tap
perl -CSD epicsExitTest.t -tap > epicsExitTest.tap
make -C std/filters/test tapfiles
perl -CSD tsTest.t -tap > tsTest.tap
perl -CSD dbndTest.t -tap > dbndTest.tap
perl -CSD epicsTimerTest.t -tap > epicsTimerTest.tap
make -C std/rec/test tapfiles
perl -CSD arrayOpTest.t -tap > arrayOpTest.tap
perl -CSD arrTest.t -tap > arrTest.tap
perl -CSD analogMonitorTest.t -tap > analogMonitorTest.tap
Starting iocInit
perl -CSD syncTest.t -tap > syncTest.tap
perl -CSD scanEventTest.t -tap > scanEventTest.tap
Starting iocInit
perl -CSD regressTest.t -tap > regressTest.tap
perl -CSD ringPointerTest.t -tap > ringPointerTest.tap
epicsThreadSetPriority called by non epics thread
perl -CSD ringBytesTest.t -tap > ringBytesTest.tap
perl -CSD callbackParallelTest.t -tap > callbackParallelTest.tap
perl -CSD dbStateTest.t -tap > dbStateTest.tap
perl -CSD epicsEventTest.t -tap > epicsEventTest.tap
perl -CSD dbCaStatsTest.t -tap > dbCaStatsTest.tap
perl -CSD scanIoTest.t -tap > scanIoTest.tap
Starting iocInit
perl -CSD dbChannelTest.t -tap > dbChannelTest.tap
perl -CSD epicsMutexTest.t -tap > epicsMutexTest.tap
Starting iocInit
perl -CSD epicsSpinTest.t -tap > epicsSpinTest.tap
Starting iocInit
perl -CSD epicsAtomicTest.t -tap > epicsAtomicTest.tap
perl -CSD macDefExpandTest.t -tap > macDefExpandTest.tap
perl -CSD macLibTest.t -tap > macLibTest.tap
perl -CSD taskwdTest.t -tap > taskwdTest.tap
perl -CSD dbChArrTest.t -tap > dbChArrTest.tap
Starting iocInit
perl -CSD chfPluginTest.t -tap > chfPluginTest.tap
chfConfigParseStart: plugin pvt alloc failed
perl -CSD arrShorthandTest.t -tap > arrShorthandTest.tap
perl -CSD recGblCheckDeadbandTest.t -tap > recGblCheckDeadbandTest.tap
perl -CSD testPutGetTest.t -tap > testPutGetTest.tap
perl -CSD blockingSockTest.t -tap > blockingSockTest.tap
perl -CSD epicsMessageQueueTest.t -tap > epicsMessageQueueTest.tap
perl -CSD epicsStackTraceTest.t -tap > epicsStackTraceTest.tap
perl -CSD ipAddrToAsciiTest.t -tap > ipAddrToAsciiTest.tap
perl -CSD osiSockTest.t -tap > osiSockTest.tap
+ make -s test-results
Breaktable.tap .. ok
DBD.tap ......... ok
Device.tap ...... ok
Driver.tap ...... ok
Function.tap .... ok
macLib.tap ...... ok
Menu.tap ........
not ok 14 - C declaration
Failed 1/14 subtests
Recfield.tap .... ok
Recordtype.tap .. ok
Registrar.tap ... ok
Snippets.tap .... ok
Variable.tap .... ok
Test Summary Report
Menu.tap      (Wstat: 0 Tests: 14 Failed: 1)
  Failed test:  14
Files=12, Tests=230,  1 wallclock secs ( 0.21 usr  0.06 sys +  0.01 cusr  0.03 csys =  0.31 CPU)
Result: FAIL
../../../../configure/RULES_BUILD:354: recipe for target 'test-results' failed
make[3]: *** [test-results] Error 1
../../../configure/RULES_ARCHS:58: recipe for target 'test-results.linux-x86' failed
make[2]: *** [test-results.linux-x86] Error 2
../configure/RULES_DIRS:84: recipe for target 'tools/test.test-results' failed
make[1]: *** [tools/test.test-results] Error 2
configure/RULES_DIRS:84: recipe for target 'src.test-results' failed
make: *** [src.test-results] Error 2
Build step 'Execute shell' marked build as failure
TAP Reports Processing: START
Looking for TAP results report in workspace using pattern: src/**/O.linux-x86/*.tap
Saving reports...
There are failed test cases. Marking build as UNSTABLE
TAP Reports Processing: FINISH
Jenkins build is back to normal : epics-base-3.15-linux32-test #219 APS Jenkins via Core-talk
Prev: Build failed in Jenkins: epics-base-3.15-win64-test #242 APS Jenkins via Core-talk
Next: Build failed in Jenkins: epics-pva2pva-vx69 #234 APS Jenkins via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Prev: Jenkins build is back to normal : epics-base-3.15-win64-test #243 APS Jenkins via Core-talk
Next: Jenkins build is back to normal : epics-base-3.15-linux32-test #219 APS Jenkins via Core-talk
ANJ, 06 Sep 2019 · Home · News · About · Talk · Base · Modules · Extensions ·
