2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Subject: Re: [Merge] ~bhill/epics-base:shared-rpath-independent-of-static-build into epics-base:7.0
From: mdavidsaver via Core-talk <[email protected]>
To: Bruce Hill <[email protected]>
Date: Thu, 26 Sep 2019 16:07:25 -0000
Mark, if you want to understand what flags were used to build a binary, then the output of 'readelf' is quite helpful.  eg. the RUNPATH entry shows the -rpath which was passed to the linker, and the NEEDED entries are the direct library dependencies (the -l passed to the linker).
$ readelf -d bin/linux-x86_64/caget |head
Dynamic section at offset 0x8d90 contains 32 entries:
  Tag        Type                         Name/Value
 0x0000000000000001 (NEEDED)             Shared library: [libca.so.4.13.3]
 0x0000000000000001 (NEEDED)             Shared library: [libCom.so.3.17.4]
 0x0000000000000001 (NEEDED)             Shared library: [libstdc++.so.6]
 0x0000000000000001 (NEEDED)             Shared library: [libm.so.6]
 0x0000000000000001 (NEEDED)             Shared library: [libgcc_s.so.1]
 0x0000000000000001 (NEEDED)             Shared library: [libc.so.6]
 0x000000000000001d (RUNPATH)            Library runpath: [$ORIGIN/../../lib/linux-x86_64]
https://code.launchpad.net/~bhill/epics-base/+git/epics-base/+merge/373243
Your team EPICS Core Developers is requested to review the proposed merge of ~bhill/epics-base:shared-rpath-independent-of-static-build into epics-base:7.0.
[Merge] ~bhill/epics-base:shared-rpath-independent-of-static-build into epics-base:7.0 Bruce Hill via Core-talk
Prev: Re: pvData introduction Kasemir, Kay via Core-talk
Next: Re: [Merge] ~bhill/epics-base:shared-rpath-independent-of-static-build into epics-base:7.0 mdavidsaver via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Prev: Re: [Merge] ~bhill/epics-base:shared-rpath-independent-of-static-build into epics-base:7.0 rivers via Core-talk
ANJ, 26 Sep 2019 · Home · News · About · Talk · Base · Modules · Extensions ·
