2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Subject: [Bug 1845854] Re: EPICS Math tests failing on Windows with MSVC
From: mdavidsaver via Core-talk <[email protected]>
To: [email protected]
Date: Wed, 02 Oct 2019 21:49:22 -0000
Most of the tests being performed in epicsCalcTest are cross-checks
between the C compiler and the calc engine.
> /* Test an expression that is also valid C code */
> #define testExpr(expr) testCalc(#expr, expr);
You received this bug notification because you are a member of EPICS
Core Developers, which is subscribed to EPICS Base.
Matching subscriptions: epics-core-list-subscription
https://bugs.launchpad.net/bugs/1845854
Title:
Status in EPICS Base:
  New
Bug description:
  Some epics base tests involving NaN and Inf have been failing for most
  windows MSVC builds, I have written a small test program
  https://github.com/FreddieAkeroyd/Testing/blob/master/src/mytests/inftest.cpp
  with output at https://ci.appveyor.com/project/FreddieAkeroyd/testing
  which illustrates the underlying cause.
  The general summary is that:
  VS2010, VS2017 and VS2019 are OK in all configurations
  For other Visual studio versions:
      Debug builds are often OK
      All release builds fail.
  The failure mode is as follows (Inf shown here but applies to NaN
  too):
  Inf – Inf is evaluated correctly
  Inf + -Inf is evaluated incorrectly
  Inf + (-Inf) is evaluated correctly on VS 11.0 and 12.0, but not 14.0
  The test code is using expressions like “a + -a” with a = Inf, if it
  instead tests “a + -b” with a = b = Inf then release mode works in all
  cases. So it looks like the repeated variable name is causing an
  undesired optimisation. I feel expressions of the form “a + -b” rather
  than “a + -a” are a better reflection of what is  likely in practice,
  if that change is acceptable then I would be happy to submit a PR to
  use different variable names within binary operation tests
  Freddie
To manage notifications about this bug go to:
https://bugs.launchpad.net/epics-base/+bug/1845854/+subscriptions
[Bug 1845854] [NEW] EPICS Math tests failing on Windows with MSVC Freddie Akeroyd via Core-talk
Prev: Re: [Merge] ~dirk.zimoch/epics-base:iocLogClientFixesTry2 into epics-base:7.0 mdavidsaver via Core-talk
Next: Build completed: epics-base base-3.15-282 AppVeyor via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Prev: [Bug 1845854] Re: EPICS Math tests failing on Windows with MSVC Dirk Zimoch via Core-talk
Next: [Bug 1845854] Re: EPICS Math tests failing on Windows with MSVC mdavidsaver via Core-talk
ANJ, 10 Oct 2019 · Home · News · About · Talk · Base · Modules · Extensions ·
