2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Subject: [Bug 1756015] Re: Wrong day light saving times in CONFIG_SITE_ENV?
From: Andrew Johnson via Core-talk <[email protected]>
To: [email protected]
Date: Thu, 31 Oct 2019 19:51:37 -0000
** Changed in: epics-base/3.15
       Status: Fix Committed => Fix Released
You received this bug notification because you are a member of EPICS
Core Developers, which is subscribed to EPICS Base.
Matching subscriptions: epics-core-list-subscription
https://bugs.launchpad.net/bugs/1756015
Title:
Status in EPICS Base:
  Fix Released
Status in EPICS Base 3.15 series:
  Fix Released
Status in EPICS Base 7.0 series:
  Fix Released
Bug description:
  I think the MET TIMEZONE examples are all wrong. In Europe daylight saving time ends 3:00 -> 2:00, not 2:00 -> 1:00 as in the US. Thus all MET TIMEZONE examples should end with 3, not 2. (As far I understand what the hour part means.)
  In spring the time is the same in EU and US: 2:00 -> 3:00
  See: https://www.timeanddate.com/time/dst/2018b.html
To manage notifications about this bug go to:
https://bugs.launchpad.net/epics-base/+bug/1756015/+subscriptions
Prev: [Bug 1801145] Re: Improve place-holder record types Andrew Johnson via Core-talk
Next: [Bug 1827225] Re: AppVeyor mingw builds broken (claiming missing epicsTempFile.obj) Andrew Johnson via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Next: [Bug 1812084] Re: Build failure on RTEMS 4.10.2 Andrew Johnson via Core-talk
ANJ, 31 Oct 2019 · Home · News · About · Talk · Base · Modules · Extensions ·
