2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Subject: [Bug 1730982] Re: Race in db_close_events()
From: Andrew Johnson via Core-talk <[email protected]>
To: [email protected]
Date: Fri, 01 Nov 2019 20:20:48 -0000
** Changed in: epics-base/3.16
       Status: Fix Committed => Fix Released
** Changed in: epics-base/3.15
You received this bug notification because you are a member of EPICS
Core Developers, which is subscribed to EPICS Base.
Matching subscriptions: epics-core-list-subscription
https://bugs.launchpad.net/bugs/1730982
Title:
Status in EPICS Base:
  Fix Released
Status in EPICS Base 3.14 series:
  Won't Fix
Status in EPICS Base 3.15 series:
  Fix Released
Status in EPICS Base 3.16 series:
  Fix Released
Status in EPICS Base 7.0 series:
  Fix Released
Bug description:
  valgrind reports a data race in db_close_events().  This is the
  pattern of:
  > epicsEventMustWait(...)
  > epicsEventDestroy(...)
  Where the working calling 'epicsEventSignal(...)' may not have
  returned before the event is destroy'd.
  I introduced this race in d2b0e920012d4c9bc0eaecc0e092cedd776db578
  prior to 3.15.0.1 to fix a similar race (the worker was calling
  epicsEventDestroy() ).
  We need a safe pattern for joining worker threads (cf. lp:1699229).
To manage notifications about this bug go to:
https://bugs.launchpad.net/epics-base/+bug/1730982/+subscriptions
Prev: [Bug 1699229] Re: Joinable threads Andrew Johnson via Core-talk
Next: [Bug 1842086] Re: TestHarness should be TESTPROD instead of PROD Andrew Johnson via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Next: Build failed: EPICS Base base-R7.0.3.1-478 AppVeyor via Core-talk
ANJ, 02 Nov 2019 · Home · News · About · Talk · Base · Modules · Extensions ·
