2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Base 7 modules/RELEASE*.local files
From: Mark Rivers via Core-talk <[email protected]>
Date: Mon, 4 Nov 2019 17:40:48 +0000
Note that the new motor directory structure, which is similar to base 7 with a modules directory, has the same problem. I have to manually delete the modules/RELEASE* files when changing the version of base, asyn etc.
It does not seem to me that this is how the build system should work.
Sent from my iPhone
On Nov 2, 2019, at 8:10 AM, Mark Rivers <[email protected]<mailto:[email protected]>> wrote:
I just updated my base-7.0.3 to base-7.0.3.1 by doing the following:
git pull
git checkout R7.0.3.1
git submodule update
Renamed the directory from base-7.0.3 to base-7.0.3.1.
make realclean realuninstall
This fails because the modules/RELEASE*.local files still refer to the old directory base-7.0.3.  I had to delete those files manually.
I find this frustrating.  Is there a reason that those files cannot be removed with realclean or realuninstall?
Base 7 modules/RELEASE*.local files Mark Rivers via Core-talk
Prev: Re: Architecture dependent dbd files Jeong Han Lee via Core-talk
Next: Re: Base 7 modules/RELEASE*.local files Johnson, Andrew N. via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Prev: Base 7 modules/RELEASE*.local files Mark Rivers via Core-talk
ANJ, 04 Nov 2019 · Home · News · About · Talk · Base · Modules · Extensions ·
