2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Subject: RE: Base 3.14.12.5 make uninstall not removing bin or lib
From: "Baker, Keith \(DLSLtd, RAL, LSCI\) via Core-talk" <[email protected]>
Date: Thu, 14 Nov 2019 11:26:25 +0000
Hi, Andrew.
Thank you.  That confirms what I was seeing. I appreciate R3.14 is quite old, so sorry for dragging you back to that, but I was surprised to see the “bug” persist through later releases.
However, you have a plan to remove the cleandirs target anyway, which will tidy things up again.
I like your plan but we actually use the cleandirs target to remove another directory we create called $(INSTALL_LOCATION)/data.
We’ll find another way to do that, probably adding it to the realuninstall recipes.
Like you say, adjusting which targets we use will get round my current problem with bin and lib, and ‘make distclean’ is shorter which I’m always happy with.
Thanks for your help.
Keith
Sent: 12 November 2019 21:53
To: Baker, Keith (DLSLtd,RAL,LSCI) <[email protected]>; [email protected]
Subject: Re: Base 3.14.12.5 make uninstall not removing bin or lib
Hi Keith,
On 11/7/19 4:01 AM, Baker, Keith (DLSLtd, RAL, LSCI) via Core-talk wrote:
After updating from R3.14.12.3 or R3.14.12.7 I now find that a “make uninstall” does not remove INSTALL_LOCATION_BIN or INSTALL_LOCATION_LIB.
In RULES_TOP the cleandirs: target checks if those directories are empty and if so removes them, but the check seems to fail even though the directories should have just been emptied by the uninstall: target.
This used to work until this change was introduced in R3.14.12.5,
-archuninstall: $(addprefix uninstall$(DIVIDER),$(BUILD_ARCHS))
-              @$(MAKE) -f Makefile cleandirs
+archuninstall: $(addprefix uninstall$(DIVIDER),$(BUILD_ARCHS)) | cleandirs
Yeah, that's a bug that I introduced, sorry! I normally use 'make distclean' which removes all the O.<arch> directories and everything under the bin and lib directories unconditionally. 'make clean uninstall' only removes files for the target architectures that this host-arch is configured to build, and is more to type anyway.
For future releases I'm probably going to remove the cleandirs target and do something like this diff against the 3.15 tree (3.14 is no longer supported):
diff --git a/configure/RULES_TOP b/configure/RULES_TOP
--- a/configure/RULES_TOP
+++ b/configure/RULES_TOP
@@ -24,25 +24,19 @@ UNINSTALL_DIRS += $(INSTALL_DBD) $(INSTALL_INCLUDE) $(INSTALL_DOC) \
 uninstallDirs:
        $(RMDIR) $(UNINSTALL_DIRS)
+EMPTY_INSTALL_DIRS = \
+    $(if $(wildcard $(INSTALL_LOCATION_BIN)/*),,$(INSTALL_LOCATION_BIN)) \
+    $(if $(wildcard $(INSTALL_LOCATION_LIB)/*),,$(INSTALL_LOCATION_LIB))
 uninstall: archuninstall uninstallDirs
+       $(RMDIR) $(EMPTY_INSTALL_DIRS)
-archuninstall: $(addprefix uninstall$(DIVIDER),$(BUILD_ARCHS)) | cleandirs
 archPart = $(word 2, $(subst $(DIVIDER), ,$@))
 uninstall$(DIVIDER)%:
        $(RMDIR) $(INSTALL_LOCATION_BIN)/$(archPart)
        $(RMDIR) $(INSTALL_LOCATION_LIB)/$(archPart)
-cleandirs:
-       @$(NOP)
-ifeq ($(wildcard $(INSTALL_LOCATION_BIN)/*),)
-       $(RMDIR) $(INSTALL_LOCATION_BIN)
-endif
-ifeq ($(wildcard $(INSTALL_LOCATION_LIB)/*),)
-       $(RMDIR) $(INSTALL_LOCATION_LIB)
-endif
 help:
        @echo "Usage: gnumake [options] [target] ..."
This does the directory-is-empty tests after their contents have been removed but without having to use a recursive make call, which is what I was originally trying to clean up. A 'make archuninstall' will no longer remove the empty top-level bin and lib directories when deleting the last remaining architecture, but 'make uninstall' is less typing and should be close enough anyway.
Thanks for the bug report,
- Andrew
Complexity comes for free, Simplicity you have to work for.
Re: Base 3.14.12.5 make uninstall not removing bin or lib Johnson, Andrew N. via Core-talk
Base 3.14.12.5 make uninstall not removing bin or lib Baker, Keith (DLSLtd, RAL, LSCI) via Core-talk
Prev: Build failed: EPICS Base base-7.0-480 AppVeyor via Core-talk
Next: Re: [Bug 1829919] [NEW] IOC segfaults when calling dbLoadRecords after iocInit Martin Konrad via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Base 3.14.12.5 make uninstall not removing bin or lib Johnson, Andrew N. via Core-talk
Next: Re: Base 3.14.12.5 make uninstall not removing bin or lib Johnson, Andrew N. via Core-talk
ANJ, 14 Nov 2019 · Home · News · About · Talk · Base · Modules · Extensions ·
