2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Subject: [Bug 1853148] Re: mingw compiler problem with printf/scanf formats
From: Andrew Johnson via Core-talk <[email protected]>
To: [email protected]
Date: Tue, 19 Nov 2019 17:50:39 -0000
We've been seeing this warning for a long time but haven't known about a
fix for it. From the links you posted it would appear that adding the
flag -D__USE_MINGW_ANSI_STDIO to OP_SYS_CPPFLAGS in
configure/os/CONFIG.Common.win32-x86-mingw might solve it (for 64-bit
builds as well), although when I just tried that it doesn't seem to
silence the warnings:
/usr/bin/x86_64-w64-mingw32-g++           -DUSE_TYPED_RSET -I../../pdbApp -I../../p2pApp -I../../common -DNOMINMAX   -D_MINGW -D__USE_MINGW_ANSI_STDIO     -O3   -Wall      -m64    -DEPICS_BUILD_DLL -DEPICS_CALL_DLL   -I. -I../O.Common -I. -I. -I.. -I/local/anj/base-7.0/include/compiler/gcc -I/local/anj/base-7.0/include/os/WIN32 -I/local/anj/base-7.0/include -I/local/anj/base-7.0/include/compiler/gcc -I/local/anj/base-7.0/include/os/WIN32 -I/local/anj/base-7.0/include        -o testpdb.obj -c ../testpdb.cpp
../testpdb.cpp: In function 'int main(int, char**)':
../testpdb.cpp:310:99: warning: unknown conversion type character 'z' in format [-Wformat=]
             testDiag("Cnt %s = %zu (%ld)", it->first.c_str(), it->second.current, it->second.delta);
../testpdb.cpp:310:99: warning: format '%ld' expects argument of type 'long int', but argument 3 has type 'size_t {aka long long unsigned int}' [-Wformat=]
../testpdb.cpp:310:99: warning: too many arguments for format [-Wformat-extra-args]
../testpdb.cpp:348:99: warning: unknown conversion type character 'z' in format [-Wformat=]
../testpdb.cpp:348:99: warning: format '%ld' expects argument of type 'long int', but argument 3 has type 'size_t {aka long long unsigned int}' [-Wformat=]
../testpdb.cpp:348:99: warning: too many arguments for format [-Wformat-extra-args]
My gcc cross-compiler is from RHEL-7, so maybe it might still help with a newer gcc/MinGW version:
tux% x86_64-w64-mingw32-g++ --version
x86_64-w64-mingw32-g++ (GCC) 4.9.3 20150626 (Fedora MinGW 4.9.3-1.el7)
If someone sees that it does help on newer versions I can add that flag
to 3.15.
** Changed in: epics-base
       Status: New => Triaged
   Importance: Undecided => Low
You received this bug notification because you are a member of EPICS
Core Developers, which is subscribed to EPICS Base.
Matching subscriptions: epics-core-list-subscription
https://bugs.launchpad.net/bugs/1853148
Title:
Status in EPICS Base:
  Triaged
Bug description:
  ../db/dbJLink.c: In function ‘dbjl_integer’:
  ../db/dbJLink.c:136:16: warning: unknown conversion type character ‘l’ in format [-Wformat=]
           printf("dbjl_integer(%s@%p, %lld)\n",
  ../db/dbJLink.c:136:16: warning: too many arguments for format [-Wformat-extra-args]
  It seems that mingw does not like "%lld".
To manage notifications about this bug go to:
https://bugs.launchpad.net/epics-base/+bug/1853148/+subscriptions
[Bug 1853148] [NEW] mingw compiler problem in dbJLink.c Dirk Zimoch via Core-talk
Prev: [Bug 1853168] Re: undefined reference to `clock_gettime' Martin Konrad via Core-talk
Next: [Bug 1853168] Re: undefined reference to `clock_gettime' mdavidsaver via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Prev: [Bug 1853148] Re: mingw compiler problem with printf/scanf formats Dirk Zimoch via Core-talk
Next: [Bug 1853148] Re: mingw compiler problem with printf/scanf formats mdavidsaver via Core-talk
ANJ, 19 Nov 2019 · Home · News · About · Talk · Base · Modules · Extensions ·
