2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Subject: Re: [Merge] ~epics-core/epics-base/+git/Com:libcom-api into epics-base:7.0
From: Ralph Lange via Core-talk <[email protected]>
To: mdavidsaver <[email protected]>
Date: Mon, 25 Nov 2019 08:24:12 -0000
I like the cleaner approach!
As granularity is by library, every library will need a header file like libComAPI.h with functionally identical content. Instead of replicating the code - could this header be generated at compile time?
(I'm not so much concerned about the replication itself - more about the number of places that have to be patched if the mechanism ever needs to be changed.)
https://code.launchpad.net/~epics-core/epics-base/+git/Com/+merge/375942
Your team EPICS Core Developers is requested to review the proposed merge of ~epics-core/epics-base/+git/Com:libcom-api into epics-base:7.0.
[Merge] ~epics-core/epics-base/+git/Com:libcom-api into epics-base:7.0 mdavidsaver via Core-talk
Prev: Re: [Merge] ~anj/epics-base/+git/base-7.0:typed-dsets into epics-base:7.0 Ralph Lange via Core-talk
Next: Build completed: epics-base base-7.0-363 AppVeyor via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Prev: [Merge] ~epics-core/epics-base/+git/Com:libcom-api into epics-base:7.0 mdavidsaver via Core-talk
Next: Re: [Merge] ~epics-core/epics-base/+git/Com:libcom-api into epics-base:7.0 mdavidsaver via Core-talk
ANJ, 25 Nov 2019 · Home · News · About · Talk · Base · Modules · Extensions ·
