2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <2020>  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <2020>  2021  2022  2023  2024  2025  2026
Subject: [Bug 1740426] Re: portable printf() spec for size_t, long long, and others
From: Martin Konrad via Core-talk <[email protected]>
To: [email protected]
Date: Tue, 07 Jan 2020 14:53:05 -0000
Mark, you're right, MSVC supports %z for size_t (which is certainly
preferred over the Microsoft-specific %I). This is supported at least
since VS 2015 (https://docs.microsoft.com/en-us/cpp/c-runtime-library
/format-specification-syntax-printf-and-wprintf-functions?view=vs-2015
#size-prefixes-for-printf-and-wprintf-format-type-specifiers). But I'm
not aware of a sane portable way of writing
int64_t i = 42;
printf("Works on Windows only: %I64d\n", i);
other than
printf("Works on all C99-compatible platforms: %"PRId64"\n", i);
Sure the following works
printf("Works on all C99-compatible platforms: %lli\n", (long long)i);
but I always have to pull up the standard to be sure the type I'm
casting to has sufficient size on all platforms. And it also requires
C99.
You received this bug notification because you are a member of EPICS
Core Developers, which is subscribed to EPICS Base.
Matching subscriptions: epics-core-list-subscription
https://bugs.launchpad.net/bugs/1740426
Title:
Status in EPICS Base:
  Triaged
Bug description:
  I've been in the habit of using '%lld' and '%zu' to print 'long long'
  and 'size_t' respectively.  However, the windows world needs '%I64d'
  and '%Iu' instead.  It would be nice to have compatibility macros for
  this.
  stdint.h/inttypes.h has a convention for this for the standard fixed
  width types.  eg. PRIx32 for 'uint32_t'.  This is used like:
  > printf("%"PRIx32"\n", (uint32_t)42);
  http://en.cppreference.com/w/c/types/integer
To manage notifications about this bug go to:
https://bugs.launchpad.net/epics-base/+bug/1740426/+subscriptions
Prev: Re: [Bug 1858467] Re: dbExpand.pl outputs records in non-deterministic order Ben Franksen via Core-talk
Next: Re: EPICS 7, pvAccess & static build Johnson, Andrew N. via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <2020>  2021  2022  2023  2024  2025  2026
Prev: [Bug 1740426] Re: portable printf() spec for size_t, long long, and others rivers via Core-talk
Next: [Bug 1740426] Re: portable printf() spec for size_t, long long, and others Martin Konrad via Core-talk
ANJ, 11 Jan 2020 · Home · News · About · Talk · Base · Modules · Extensions ·
