2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <2020>  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <2020>  2021  2022  2023  2024  2025  2026
Subject: Re: PVA without Base?
From: Mark Rivers via Core-talk <[email protected]>
To: Ralph Lange <[email protected]>
Date: Thu, 9 Jan 2020 14:13:06 +0000
Does PVA use libCom for OS independence?
I do have a mode where asyn builds with only libCom, no other libraries from base.
From: Core-talk <[email protected]> on behalf of Ralph Lange via Core-talk <[email protected]>
Sent: Thursday, January 9, 2020 7:40 AM
To: EPICS Core Talk
Subject: PVA without Base?
Interesting question that just came up:
Is it possible (maybe with the cmake approach that I remember Martin and/or Michael using) to build the pvData/pvAccess C++ libraries completely separate, i.e. without linking to or having EPICS Base around?
Background:
ITER's Real-Time Framework (RTF) that will be running the plasma control system is classified as software integrity level 1 (SWIL-1), requiring it among other stuff to adhere to the HIC++ standard and provide pretty good test coverage (>95%).
Now the RTF wants to use PVAccess as transport layer for configuration, slow control and monitoring. This would obviously pull the PVA source code into the SWIL-1 scope. Will we be able to keep the rest of EPICS Base out of this?
Thanks for any insights.
~Ralph
PVA without Base? Ralph Lange via Core-talk
Prev: PVA without Base? Ralph Lange via Core-talk
Next: Re: PVA without Base? Johnson, Andrew N. via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <2020>  2021  2022  2023  2024  2025  2026
ANJ, 09 Jan 2020 · Home · News · About · Talk · Base · Modules · Extensions ·
