2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <2020>  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <2020>  2021  2022  2023  2024  2025  2026
Subject: Re: pvput JSON syntax
From: Ralph Lange via Core-talk <[email protected]>
To: EPICS Core Talk <[email protected]>
Date: Thu, 16 Jan 2020 13:16:05 +0100
Interesting...
How does your pvput get anything starting with an "{" around the check at
Can you show what's happening when you run the command from the usage message, i.e.
pvput double01 {"value":1.234}
The "JSON support is present" line in "-h" output is printed unconditionally.
Clueless,
~Ralph
Re: pvput JSON syntax Michael Davidsaver via Core-talk
pvput JSON syntax Ralph Lange via Core-talk
Re: pvput JSON syntax Timo Korhonen via Core-talk
Prev: Re: pvput JSON syntax Mark Rivers via Core-talk
Next: Re: pvput JSON syntax Michael Davidsaver via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <2020>  2021  2022  2023  2024  2025  2026
Prev: Re: pvput JSON syntax Timo Korhonen via Core-talk
ANJ, 16 Jan 2020 · Home · News · About · Talk · Base · Modules · Extensions ·
