2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <2020>  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <2020>  2021  2022  2023  2024  2025  2026
Subject: [Bug 1861612] Re: callbackRequestDelay not waiting for 1/60 sec on vxWorks
From: rivers via Core-talk <core-talk at aps.anl.gov>
To: core-talk at aps.anl.gov
Date: Sun, 02 Feb 2020 15:54:12 -0000
> Looking at release notes and commits
>   https://github.com/epics-base/epics-base/compare/R7.0.3...R7.0.3.1
> it looks like this could be a side
> Wasn't 1/60 the default tick time on VxWorks? effect of switching
internal timers to monotonic time.
Yes, I discussed both of these in the tech-talk thread.
The Application Developers Guide does not document a minimum value for
the delay time in callbackRequestDelay().  Given that, the existing
behavior should be preserved, which was that 1/60. second did not result
in 0 delay.  I believe that has been the behavior since at least the
beginning of 3.14.
A reasonable expectation for the minimum value of the delay, given that
it is not documented, is that it should be the same as the minimum value
of epicsThreadSleep.  That is documented as follows:
"Sleep for the specified period of time, i.e. sleep without using the cpu.
If delay is >0 then the thread will sleep at least until the next clock tick.
The exact time is determined by the underlying architecture. If delay is
<= 0 then a delay of 0 is requested of the underlying architecture. What
happens is architecture dependent but often it allows other threads of the
same priority to run."
You received this bug notification because you are a member of EPICS
Core Developers, which is subscribed to EPICS Base.
Matching subscriptions: epics-core-list-subscription
https://bugs.launchpad.net/bugs/1861612
Title:
Status in EPICS Base:
  New
Bug description:
  The problem is documented in this tech-talk thread:
  https://epics.anl.gov/tech-talk/2020/msg00308.php
  In 7.0.3.1, but not in 7.0.3, callbackRequestDelay(1/60) results in
  100% CPU time, most of the time in cbHigh.
  This happens on vxWorks 6.9.4.1 and was first seen with the scaler
  record with multiple types of scaler hardware and device support.
To manage notifications about this bug go to:
https://bugs.launchpad.net/epics-base/+bug/1861612/+subscriptions
[Bug 1861612] [NEW] callbackRequestDelay not waiting for 1/60 sec on vxWorks rivers via Core-talk
Prev: [Bug 1861612] Re: callbackRequestDelay not waiting for 1/60 sec on vxWorks Ralph Lange via Core-talk
Next: [Bug 1861612] Re: callbackRequestDelay not waiting for 1/60 sec on vxWorks Ralph Lange via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <2020>  2021  2022  2023  2024  2025  2026
ANJ, 02 Feb 2020 · Home · News · About · Talk · Base · Modules · Extensions ·
