2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <2020>  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <2020>  2021  2022  2023  2024  2025  2026
Subject: [Bug 1861612] Re: callbackRequestDelay not waiting for 1/60 sec on vxWorks
From: rivers via Core-talk <core-talk at aps.anl.gov>
To: core-talk at aps.anl.gov
Date: Sun, 02 Feb 2020 16:58:45 -0000
Perhaps my hypothesis about callbackRequestDelay behavior change is
wrong.
I looked for where callbackRequestDelay is used in base, and it seems to
be used in the HIGH delay for bo records. I thus thought that HIGH
delays of 1/60. second or less would result in effectively 0 delay.
However, I tested this with camonitor in a vxWorks IOC running 7.0.3.1.
This is what I see with HIGH=0.01, which is less than 1 tick
time=0.016666666.  This is as I repeatedly write 1 to the record with
caput.
corvette:~/devel/PY_NTNDA_Viewer>camonitor -tic 13LAB:userTranEnable
13LAB:userTranEnable           (2020-02-02 10:41:57.387524) Disable
13LAB:userTranEnable                         (   +4.306785) Enable
13LAB:userTranEnable                         (   +0.007119) Disable
13LAB:userTranEnable                         (   +0.346203) Enable
13LAB:userTranEnable                         (   +0.003968) Disable
13LAB:userTranEnable                         (   +0.313715) Enable
13LAB:userTranEnable                         (   +0.002799) Disable
13LAB:userTranEnable                         (   +0.236848) Enable
13LAB:userTranEnable                         (   +0.013807) Disable
13LAB:userTranEnable                         (   +0.290088) Enable
13LAB:userTranEnable                         (   +0.009729) Disable
13LAB:userTranEnable                         (   +0.249017) Enable
13LAB:userTranEnable                         (   +0.017225) Disable
13LAB:userTranEnable                         (   +0.290018) Enable
13LAB:userTranEnable                         (   +0.010037) Disable
13LAB:userTranEnable                         (   +0.192072) Enable
13LAB:userTranEnable                         (   +0.008027) Disable
13LAB:userTranEnable                         (   +0.200641) Enable
13LAB:userTranEnable                         (   +0.015982) Disable
13LAB:userTranEnable                         (   +0.208282) Enable
13LAB:userTranEnable                         (   +0.008714) Disable
13LAB:userTranEnable                         (   +0.230697) Enable
13LAB:userTranEnable                         (   +0.002203) Disable
13LAB:userTranEnable                         (   +0.206095) Enable
13LAB:userTranEnable                         (   +0.010524) Disable
13LAB:userTranEnable                         (   +0.197474) Enable
13LAB:userTranEnable                         (   +0.002590) Disable
13LAB:userTranEnable                         (   +0.174295) Enable
13LAB:userTranEnable                         (   +0.009070) Disable
So the transition from 1 (Enable) to 0 (Disable) seems to take a random
amount of time between 0 and 0.01666 seconds.  This is exactly what I
expect if the delay does wait for the next clock tick, just like
epicsThreadSleep. The tick rate in my IOC is 60.
However, if I change HIGH from .01 to .005 the behavior changes, and it
is only high for 20-40 microseconds (measuring time on a Linux client).
13LAB:userTranEnable           (2020-02-02 10:52:10.095757) Disable
13LAB:userTranEnable                         (  +11.698305) Enable
13LAB:userTranEnable                         (   +0.000056) Disable
13LAB:userTranEnable                         (   +0.752278) Enable
13LAB:userTranEnable                         (   +0.000034) Disable
13LAB:userTranEnable                         (   +0.239082) Enable
13LAB:userTranEnable                         (   +0.000037) Disable
13LAB:userTranEnable                         (   +0.223219) Enable
13LAB:userTranEnable                         (   +0.000038) Disable
13LAB:userTranEnable                         (   +0.178778) Enable
13LAB:userTranEnable                         (   +0.000028) Disable
13LAB:userTranEnable                         (   +0.314707) Enable
13LAB:userTranEnable                         (   +0.000036) Disable
13LAB:userTranEnable                         (   +0.096827) Enable
13LAB:userTranEnable                         (   +0.000030) Disable
13LAB:userTranEnable                         (   +0.176998) Enable
13LAB:userTranEnable                         (   +0.193591) Enable
13LAB:userTranEnable                         (   +0.000022) Disable
13LAB:userTranEnable                         (   +0.191531) Enable
13LAB:userTranEnable                         (   +0.000031) Disable
13LAB:userTranEnable                         (   +0.207274) Enable
13LAB:userTranEnable                         (   +0.000024) Disable
Why is there a change in behavior between HIGH = 0.01 and 0.005?
I have not done the same experiment on 7.0.3.
You received this bug notification because you are a member of EPICS
Core Developers, which is subscribed to EPICS Base.
Matching subscriptions: epics-core-list-subscription
https://bugs.launchpad.net/bugs/1861612
Title:
Status in EPICS Base:
  New
Bug description:
  The problem is documented in this tech-talk thread:
  https://epics.anl.gov/tech-talk/2020/msg00308.php
  In 7.0.3.1, but not in 7.0.3, callbackRequestDelay(1/60) results in
  100% CPU time, most of the time in cbHigh.
  This happens on vxWorks 6.9.4.1 and was first seen with the scaler
  record with multiple types of scaler hardware and device support.
To manage notifications about this bug go to:
https://bugs.launchpad.net/epics-base/+bug/1861612/+subscriptions
[Bug 1861612] [NEW] callbackRequestDelay not waiting for 1/60 sec on vxWorks rivers via Core-talk
Prev: [Bug 1861612] Re: callbackRequestDelay not waiting for 1/60 sec on vxWorks Ralph Lange via Core-talk
Next: [Bug 1861612] Re: callbackRequestDelay not waiting for 1/60 sec on vxWorks rivers via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <2020>  2021  2022  2023  2024  2025  2026
ANJ, 02 Feb 2020 · Home · News · About · Talk · Base · Modules · Extensions ·
