2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <2020>  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <2020>  2021  2022  2023  2024  2025  2026
Subject: [Bug 1861612] Re: callbackRequestDelay not waiting for 1/60 sec on vxWorks
From: rivers via Core-talk <core-talk at aps.anl.gov>
To: core-talk at aps.anl.gov
Date: Mon, 03 Feb 2020 14:52:31 -0000
I do see the message that Andrew referred to when the IOC boots:
osdMonotonicInit: Measuring CPU time-base frequency ... 25000172 ticks/sec.
I just modified the scaler record to print the current value of the
first counter in the callback routine.  I print with errlogPrintf(),
rather than printf(), so it does not slow down the operation very much.
My scaler has a 10 MHz input on scaler[0], so the ticks are 100 ns.
This is what I see if the RATE=59. The expected delta tick is
1/59.*1e7=169492.  The average delta for the first 6 readings is 163981,
which is pretty close.
updateCounts: posting scaler values counts[0]=74
updateCounts: posting scaler values counts[0]=150723
updateCounts: posting scaler values counts[0]=317296
updateCounts: posting scaler values counts[0]=483968
updateCounts: posting scaler values counts[0]=651202
updateCounts: posting scaler values counts[0]=817458
updateCounts: posting scaler values counts[0]=983962
This is what I see if RATE=60
updateCounts: posting scaler values counts[0]=186497
updateCounts: posting scaler values counts[0]=188068
updateCounts: posting scaler values counts[0]=188639
updateCounts: posting scaler values counts[0]=189067
updateCounts: posting scaler values counts[0]=189495
updateCounts: posting scaler values counts[0]=189924
updateCounts: posting scaler values counts[0]=190351
So now the average delta from the last 7 readings is 642 ticks, which
means the callback is running every 64 microseconds, or 15.6 kHz.
This confirms that the problem is indeed that the callback is being
called far too often when RATE=60.
If the problem is that callbackRequestDelay is returning too soon when
RATE=60 then I don't understand why the bo record .HIGH field is not
showing the same problem.
You received this bug notification because you are a member of EPICS
Core Developers, which is subscribed to EPICS Base.
Matching subscriptions: epics-core-list-subscription
https://bugs.launchpad.net/bugs/1861612
Title:
Status in EPICS Base:
  New
Bug description:
  The problem is documented in this tech-talk thread:
  https://epics.anl.gov/tech-talk/2020/msg00308.php
  In 7.0.3.1, but not in 7.0.3, callbackRequestDelay(1/60) results in
  100% CPU time, most of the time in cbHigh.
  This happens on vxWorks 6.9.4.1 and was first seen with the scaler
  record with multiple types of scaler hardware and device support.
To manage notifications about this bug go to:
https://bugs.launchpad.net/epics-base/+bug/1861612/+subscriptions
[Bug 1861612] [NEW] callbackRequestDelay not waiting for 1/60 sec on vxWorks rivers via Core-talk
Prev: [Bug 1861612] Re: callbackRequestDelay not waiting for 1/60 sec on vxWorks rivers via Core-talk
Next: [Bug 1861612] Re: callbackRequestDelay not waiting for 1/60 sec on vxWorks Ralph Lange via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <2020>  2021  2022  2023  2024  2025  2026
ANJ, 03 Feb 2020 · Home · News · About · Talk · Base · Modules · Extensions ·
