2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <2020>  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <2020>  2021  2022  2023  2024  2025  2026
Subject: Build failed in Jenkins: EPICS-3.15 #226
From: Jenkins EPICS PSI via Core-talk <core-talk at aps.anl.gov>
To: <dirk.zimoch at psi.ch>, <core-talk at aps.anl.gov>
Date: Mon, 3 Feb 2020 19:02:10 +0100
See <http://gfa-sls2-test:8080/job/EPICS-3.15/226/display/redirect>
Started by an SCM change
Building in workspace <http://gfa-sls2-test:8080/job/EPICS-3.15/ws/>
[WS-CLEANUP] Deleting project workspace...
[WS-CLEANUP] Deferred wipeout is used...
[WS-CLEANUP] Done
Cloning the remote Git repository
Cloning repository https://git.launchpad.net/epics-base
 > git init <http://gfa-sls2-test:8080/job/EPICS-3.15/ws/> # timeout=10
Fetching upstream changes from https://git.launchpad.net/epics-base
 > git --version # timeout=10
 > git fetch --tags --progress https://git.launchpad.net/epics-base +refs/heads/*:refs/remotes/origin/*
 > git config remote.origin.url https://git.launchpad.net/epics-base # timeout=10
 > git config --add remote.origin.fetch +refs/heads/*:refs/remotes/origin/* # timeout=10
 > git rev-parse origin/3.15^{commit} # timeout=10
 > git rev-parse 3.15^{commit} # timeout=10
ERROR: Couldn't find any revision to build. Verify the repository and branch configuration for this job.
[WARNINGS] Skipping publisher since build result is FAILURE
Jenkins build is back to normal : EPICS-3.15 #227 Jenkins EPICS PSI via Core-talk
Prev: Build failed in Jenkins: epics-base-7.0-win64 #84 APS Jenkins via Core-talk
Next: Jenkins build became unstable: epics-base-3.15-win64s-test #262 APS Jenkins via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <2020>  2021  2022  2023  2024  2025  2026
Prev: Jenkins build is back to normal : epics-base-7.0-win64 #85 APS Jenkins via Core-talk
Next: Jenkins build is back to normal : EPICS-3.15 #227 Jenkins EPICS PSI via Core-talk
ANJ, 07 Feb 2020 · Home · News · About · Talk · Base · Modules · Extensions ·
