2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <2020>  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <2020>  2021  2022  2023  2024  2025  2026
Subject: [Bug 1861612] Re: callbackRequestDelay not waiting for 1/60 sec on vxWorks
From: mdavidsaver via Core-talk <core-talk at aps.anl.gov>
To: core-talk at aps.anl.gov
Date: Mon, 03 Feb 2020 22:22:22 -0000
The difference between expected and actual seems ~=
epicsThreadSleepQuantum() (aka. 1.0/sysClkRateGet() ).  This is the
granularity of epicsEventWaitWithTimeout() which is ultimately (I think)
what the timer queue is using.
The code in epicsEventWaitWithTimeout() may explain what the
-quantum()/2 was doing.
>    if (timeOut <= 0.0) {
>        ticks = 0;
>    } else if (timeOut >= (double) INT_MAX / rate) {
>        ticks = WAIT_FOREVER;
>    } else {
>        ticks = timeOut * rate; // MD - rate=sysClkRateGet()
>        if (ticks <= 0)
>            ticks = 1;
Previously, subtracting could result in timeOut <=0.  Now, this is never
the case so the minimum wait is 1 tick.
You received this bug notification because you are a member of EPICS
Core Developers, which is subscribed to EPICS Base.
Matching subscriptions: epics-core-list-subscription
https://bugs.launchpad.net/bugs/1861612
Title:
Status in EPICS Base:
  New
Bug description:
  The problem is documented in this tech-talk thread:
  https://epics.anl.gov/tech-talk/2020/msg00308.php
  In 7.0.3.1, but not in 7.0.3, callbackRequestDelay(1/60) results in
  100% CPU time, most of the time in cbHigh.
  This happens on vxWorks 6.9.4.1 and was first seen with the scaler
  record with multiple types of scaler hardware and device support.
To manage notifications about this bug go to:
https://bugs.launchpad.net/epics-base/+bug/1861612/+subscriptions
[Bug 1861612] [NEW] callbackRequestDelay not waiting for 1/60 sec on vxWorks rivers via Core-talk
Prev: [Bug 1861612] Re: callbackRequestDelay not waiting for 1/60 sec on vxWorks rivers via Core-talk
Next: Jenkins build is back to normal : epics-base-7.0-win64 #85 APS Jenkins via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <2020>  2021  2022  2023  2024  2025  2026
Next: [Bug 1861612] Re: callbackRequestDelay not waiting for 1/60 sec on vxWorks mdavidsaver via Core-talk
ANJ, 07 Feb 2020 · Home · News · About · Talk · Base · Modules · Extensions ·
