2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <2020>  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <2020>  2021  2022  2023  2024  2025  2026
Subject: Re: Weird CAS hangup on IOC
From: Michael Davidsaver via Core-talk <core-talk at aps.anl.gov>
To: Ralph Lange <ralph.lange at gmx.de>, EPICS Core Talk <core-talk at aps.anl.gov>
Date: Thu, 6 Feb 2020 10:28:36 -0800
Which version of Base is involved?  3.15?
If it's 7.0 then I think I have a fix in the queue (waiting on appveyor).
My attempt to fix epicsSocketEnableAddressUseForDatagramFanout() on vxWorks (which still needs confirmation)
and RTEMS had a side-effect on Linux where it seems that SO_REUSEADDR
and SO_REUSEPORT have the same effect, but are not interchangeable.
On 2/6/20 4:16 AM, Ralph Lange via Core-talk wrote:
> Dear Core-talkers,
> We have been seeing an IOC lately that occasionally seems to boot fine, does not print the usual "cas warning: Configured TCP port was unavailable. [...]" messages for not being the first one on the host, but then emits a
> CAS: Listen error: Address already in use
> Thread CAS-TCP (0x3337a20) suspended
> and becomes CA unresponsive.
> We recently changed our IOC startup to be systemd controlled and are starting all IOCs in parallel.
> Question: Is there a vulnerability for a race condition where two IOCs are under the impression of being able to use the original CA port, but one of them eventually fails to listen()?
> Cheers,
> ~Ralph
Attachment: signature.asc
Description: OpenPGP digital signature
Re: Weird CAS hangup on IOC Ralph Lange via Core-talk
Re: Weird CAS hangup on IOC Andrew Johnson via Core-talk
Prev: Re: Weird CAS hangup on IOC Torsten Bögershausen via Core-talk
Next: Re: Weird CAS hangup on IOC Ralph Lange via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <2020>  2021  2022  2023  2024  2025  2026
ANJ, 06 Feb 2020 · Home · News · About · Talk · Base · Modules · Extensions ·
