2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <2020>  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <2020>  2021  2022  2023  2024  2025  2026
Subject: [Bug 1863075] [NEW] Possible null pointer dereferening in shared function in modules/libcom/src/osi/os/WIN32/osdThread.c
From: Karl Vestin via Core-talk <core-talk at aps.anl.gov>
To: core-talk at aps.anl.gov
Date: Thu, 13 Feb 2020 09:57:47 -0000
Public bug reported:
If the  epicsThreadIsSuspended ( epicsThreadId id ) function in
modules/libcom/src/osi/os/WIN32/osdThread.c is called with epicsThreadId
== NULL the NULL pointer will be dereferenced, presumably causing a
crash.
This is flagged as an error by the Codacy static code analysis.
Codacy link: https://app.codacy.com/gh/epics-base/epics-
base/file/42103575235/issues/source?bid=16430872&fileBranchId=16430872#l766
** Affects: epics-base
     Importance: Undecided
         Status: New
** Tags: codacy
You received this bug notification because you are a member of EPICS
Core Developers, which is subscribed to EPICS Base.
Matching subscriptions: epics-core-list-subscription
https://bugs.launchpad.net/bugs/1863075
Title:
Status in EPICS Base:
  New
Bug description:
  epicsThreadId == NULL the NULL pointer will be dereferenced,
  presumably causing a crash.
To manage notifications about this bug go to:
https://bugs.launchpad.net/epics-base/+bug/1863075/+subscriptions
Prev: Build failed: EPICS Base base-7.0-523 AppVeyor via Core-talk
Next: [Bug 1863076] [NEW] Printf format string not matching parameter count in modules/libcom/src/osi/os/default/osdNetIntf.c Karl Vestin via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <2020>  2021  2022  2023  2024  2025  2026
ANJ, 13 Feb 2020 · Home · News · About · Talk · Base · Modules · Extensions ·
