2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <2020>  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <2020>  2021  2022  2023  2024  2025  2026
Subject: [Bug 1863077] [NEW] Possible memory leak in modules/libcom/src/osi/os/default/osdThreadHooks.c
From: Karl Vestin via Core-talk <core-talk at aps.anl.gov>
To: core-talk at aps.anl.gov
Date: Thu, 13 Feb 2020 10:08:27 -0000
Public bug reported:
In the epicsThreadHookAdd(EPICS_THREAD_HOOK_ROUTINE hook) function in
modules/libcom/src/osi/os/default/osdThreadHooks.c memory is allocated
for pHook. Then a mutex is calimed and if successful the hook is added
to a list of hook. If th emutex fails however the memory for the pHook
is not freed.
This is reported as an error by the Codacy static code analysis.
Codacy link: https://app.codacy.com/gh/epics-base/epics-
base/file/42103575134/issues/source?bid=16430872&fileBranchId=16430872#l75
** Affects: epics-base
     Importance: Undecided
         Status: New
** Tags: codacy
You received this bug notification because you are a member of EPICS
Core Developers, which is subscribed to EPICS Base.
Matching subscriptions: epics-core-list-subscription
https://bugs.launchpad.net/bugs/1863077
Title:
Status in EPICS Base:
  New
Bug description:
  is not freed.
To manage notifications about this bug go to:
https://bugs.launchpad.net/epics-base/+bug/1863077/+subscriptions
Prev: [Bug 1863076] [NEW] Printf format string not matching parameter count in modules/libcom/src/osi/os/default/osdNetIntf.c Karl Vestin via Core-talk
Next: [Bug 1863079] [NEW] Possible memory leak in modules/libcom/src/osi/os/vxWorks/osdThread.c Karl Vestin via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <2020>  2021  2022  2023  2024  2025  2026
ANJ, 13 Feb 2020 · Home · News · About · Talk · Base · Modules · Extensions ·
