2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <2020>  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <2020>  2021  2022  2023  2024  2025  2026
Subject: Build failed in Jenkins: epics-base-3.15-linux32-test #256
From: APS Jenkins via Core-talk <core-talk at aps.anl.gov>
To: core-talk at aps.anl.gov
Date: Sun, 16 Feb 2020 19:13:38 -0600 (CST)
See <https://jenkins.aps.anl.gov/job/epics-base-3.15-linux32-test/256/display/redirect>
Changes:
[...truncated 3.14 KB...]
perl -CSD Variable.t -tap > Variable.tap
make[3]: Nothing to be done for 'tapfiles'.
make -C libCom/RTEMS tapfiles
make -C ca/client tapfiles
make -C O.linux-x86 -f ../Makefile TOP=../../../.. \
    T_A=linux-x86 tapfiles
make -C ca/client/tools tapfiles
make -C ca/legacy/gdd tapfiles
make -C ./ioc tapfiles
make -C ca/client/perl tapfiles
make -C O.linux-x86 -f ../Makefile TOP=../../../../.. \
make -C O.linux-x86 -f ../Makefile TOP=../../.. \
make -C libCom/test tapfiles
make -C ca/legacy/pcas tapfiles
make -C ./build tapfiles
make -C O.linux-x86 -f ../Makefile TOP=../../../../../.. \
perl -CSD epicsUnitTestTest.t -tap > epicsUnitTestTest.tap
perl -CSD epicsTypesTest.t -tap > epicsTypesTest.tap
perl -CSD epicsInlineTest.t -tap > epicsInlineTest.tap
perl -CSD epicsCalcTest.t -tap > epicsCalcTest.tap
perl -CSD epicsAlgorithmTest.t -tap > epicsAlgorithmTest.tap
perl -CSD epicsMathTest.t -tap > epicsMathTest.tap
perl -CSD epicsMMIOTest.t -tap > epicsMMIOTest.tap
perl -CSD epicsEllTest.t -tap > epicsEllTest.tap
make[4]: Nothing to be done for 'tapfiles'.
make -C ./example tapfiles
perl -CSD epicsEnvTest.t -tap > epicsEnvTest.tap
perl -CSD epicsEnvUnsetTest.t -tap > epicsEnvUnsetTest.tap
perl -CSD epicsErrlogTest.t -tap > epicsErrlogTest.tap
perl -CSD epicsStdioTest.t -tap > epicsStdioTest.tap
make -C ./directoryService tapfiles
perl -CSD epicsStdlibTest.t -tap > epicsStdlibTest.tap
make -C O.linux-x86 -f ../Makefile TOP=../../../../../../.. \
perl -CSD epicsSockResolveTest.t -tap > epicsSockResolveTest.tap
perl -CSD epicsStringTest.t -tap > epicsStringTest.tap
perl -CSD epicsTimeTest.t -tap > epicsTimeTest.tap
make[5]: Nothing to be done for 'tapfiles'.
perl -CSD epicsTimeZoneTest.t -tap > epicsTimeZoneTest.tap
perl -CSD epicsThreadTest.t -tap > epicsThreadTest.tap
make -C ca/legacy/pcas/ex tapfiles
make -C ioc/db/test tapfiles
perl -CSD dbShutdownTest.t -tap > dbShutdownTest.tap
/bin/sh: line 1: 30425 Aborted                 perl -CSD dbShutdownTest.t -tap > dbShutdownTest.tap
../../../../../configure/RULES_BUILD:375: recipe for target 'dbShutdownTest.tap' failed
make[3]: [dbShutdownTest.tap] Error 134 (ignored)
perl -CSD dbPutLinkTest.t -tap > dbPutLinkTest.tap
log client: connected to log server at "127.0.0.1:52123"
/bin/sh: line 1: 30455 Aborted                 perl -CSD dbPutLinkTest.t -tap > dbPutLinkTest.tap
../../../../../configure/RULES_BUILD:375: recipe for target 'dbPutLinkTest.tap' failed
make[3]: [dbPutLinkTest.tap] Error 134 (ignored)
perl -CSD dbLockTest.t -tap > dbLockTest.tap
perl -CSD testdbConvert.t -tap > testdbConvert.tap
perl -CSD callbackTest.t -tap > callbackTest.tap
perl -CSD epicsThreadClassTest.t -tap > epicsThreadClassTest.tap
make -C ioc/dbtemplate/test tapfiles
perl -CSD msi.t -tap > msi.tap
perl -CSD callbackParallelTest.t -tap > callbackParallelTest.tap
perl -CSD dbStateTest.t -tap > dbStateTest.tap
perl -CSD epicsThreadOnceTest.t -tap > epicsThreadOnceTest.tap
perl -CSD dbCaStatsTest.t -tap > dbCaStatsTest.tap
make -C ./std tapfiles
perl -CSD scanIoTest.t -tap > scanIoTest.tap
Starting iocInit
perl -CSD epicsThreadPriorityTest.t -tap > epicsThreadPriorityTest.tap
perl -CSD epicsThreadPrivateTest.t -tap > epicsThreadPrivateTest.tap
/bin/sh: line 1: 30761 Aborted                 perl -CSD scanIoTest.t -tap > scanIoTest.tap
../../../../../configure/RULES_BUILD:375: recipe for target 'scanIoTest.tap' failed
make[3]: [scanIoTest.tap] Error 134 (ignored)
perl -CSD dbChannelTest.t -tap > dbChannelTest.tap
make -C std/filters/test tapfiles
perl -CSD tsTest.t -tap > tsTest.tap
perl -CSD epicsThreadHooksTest.t -tap > epicsThreadHooksTest.tap
perl -CSD dbndTest.t -tap > dbndTest.tap
perl -CSD arrTest.t -tap > arrTest.tap
perl -CSD epicsThreadPoolTest.t -tap > epicsThreadPoolTest.tap
perl -CSD syncTest.t -tap > syncTest.tap
perl -CSD epicsExitTest.t -tap > epicsExitTest.tap
perl -CSD decTest.t -tap > decTest.tap
perl -CSD epicsTimerTest.t -tap > epicsTimerTest.tap
perl -CSD ringPointerTest.t -tap > ringPointerTest.tap
epicsThreadSetPriority called by non epics thread
perl -CSD ringBytesTest.t -tap > ringBytesTest.tap
perl -CSD dbChArrTest.t -tap > dbChArrTest.tap
Starting iocInit
make -C std/rec/test tapfiles
perl -CSD epicsEventTest.t -tap > epicsEventTest.tap
perl -CSD arrayOpTest.t -tap > arrayOpTest.tap
perl -CSD analogMonitorTest.t -tap > analogMonitorTest.tap
Starting iocInit
perl -CSD scanEventTest.t -tap > scanEventTest.tap
Starting iocInit
perl -CSD regressTest.t -tap > regressTest.tap
perl -CSD chfPluginTest.t -tap > chfPluginTest.tap
chfConfigParseStart: plugin pvt alloc failed
perl -CSD arrShorthandTest.t -tap > arrShorthandTest.tap
perl -CSD recGblCheckDeadbandTest.t -tap > recGblCheckDeadbandTest.tap
perl -CSD testPutGetTest.t -tap > testPutGetTest.tap
/bin/sh: line 1: 31082 Aborted                 perl -CSD regressTest.t -tap > regressTest.tap
../../../../../configure/RULES_BUILD:375: recipe for target 'regressTest.tap' failed
make[3]: [regressTest.tap] Error 134 (ignored)
perl -CSD epicsMutexTest.t -tap > epicsMutexTest.tap
perl -CSD epicsSpinTest.t -tap > epicsSpinTest.tap
perl -CSD epicsAtomicTest.t -tap > epicsAtomicTest.tap
perl -CSD macDefExpandTest.t -tap > macDefExpandTest.tap
perl -CSD macLibTest.t -tap > macLibTest.tap
perl -CSD taskwdTest.t -tap > taskwdTest.tap
perl -CSD blockingSockTest.t -tap > blockingSockTest.tap
perl -CSD epicsMessageQueueTest.t -tap > epicsMessageQueueTest.tap
perl -CSD epicsStackTraceTest.t -tap > epicsStackTraceTest.tap
perl -CSD ipAddrToAsciiTest.t -tap > ipAddrToAsciiTest.tap
perl -CSD osiSockTest.t -tap > osiSockTest.tap
+ make -sk test-results
Breaktable.tap .. ok
DBD.tap ......... ok
Device.tap ...... ok
Driver.tap ...... ok
Function.tap .... ok
macLib.tap ...... ok
Menu.tap ........ ok
Recfield.tap .... ok
Recordtype.tap .. ok
Registrar.tap ... ok
Snippets.tap .... ok
Variable.tap .... ok
All tests successful.
Files=12, Tests=230,  1 wallclock secs ( 0.21 usr  0.09 sys +  0.01 cusr  0.03 csys =  0.34 CPU)
Result: PASS
epicsUnitTestTest.tap ........ ok
epicsTypesTest.tap ........... ok
epicsInlineTest.tap .......... ok
epicsCalcTest.tap ............ ok
epicsAlgorithmTest.tap ....... ok
epicsMathTest.tap ............ ok
epicsMMIOTest.tap ............ ok
epicsEllTest.tap ............. ok
epicsEnvTest.tap ............. ok
epicsEnvUnsetTest.tap ........ ok
epicsErrlogTest.tap .......... ok
epicsStdioTest.tap ........... ok
epicsStdlibTest.tap .......... ok
epicsSockResolveTest.tap ..... ok
epicsStringTest.tap .......... ok
epicsTimeTest.tap ............ ok
epicsTimeZoneTest.tap ........ ok
epicsThreadTest.tap .......... ok
epicsThreadClassTest.tap ..... ok
epicsThreadOnceTest.tap ...... ok
epicsThreadPriorityTest.tap .. ok
epicsThreadPrivateTest.tap ... ok
epicsThreadHooksTest.tap ..... ok
epicsThreadPoolTest.tap ...... ok
epicsExitTest.tap ............ ok
epicsTimerTest.tap ........... ok
ringPointerTest.tap .......... ok
ringBytesTest.tap ............ ok
epicsEventTest.tap ........... ok
epicsMutexTest.tap ........... ok
epicsSpinTest.tap ............ ok
epicsAtomicTest.tap .......... ok
macDefExpandTest.tap ......... ok
macLibTest.tap ............... ok
taskwdTest.tap ............... ok
blockingSockTest.tap ......... ok
epicsMessageQueueTest.tap .... ok
epicsStackTraceTest.tap ...... ok
ipAddrToAsciiTest.tap ........ ok
osiSockTest.tap .............. ok
Files=40, Tests=2911,  2 wallclock secs ( 1.44 usr  0.27 sys +  0.03 cusr  0.13 csys =  1.87 CPU)
Result: PASS
Bailout called.  Further testing stopped:  Failed to load test database
FAILED--Further testing stopped: Failed to load test database
../../../../../configure/RULES_BUILD:354: recipe for target 'test-results' failed
make[3]: *** [test-results] Error 255
../../../../configure/RULES_ARCHS:58: recipe for target 'test-results.linux-x86' failed
make[2]: *** [test-results.linux-x86] Error 2
make[2]: Target 'test-results' not remade because of errors.
../configure/RULES_DIRS:84: recipe for target 'ioc/db/test.test-results' failed
make[1]: *** [ioc/db/test.test-results] Error 2
msi.tap .. ok
Files=1, Tests=12,  0 wallclock secs ( 0.06 usr +  0.03 sys =  0.09 CPU)
Result: PASS
tsTest.tap .... ok
dbndTest.tap .. ok
arrTest.tap ... ok
syncTest.tap .. ok
decTest.tap ... ok
Files=5, Tests=1809,  1 wallclock secs ( 0.87 usr  0.06 sys +  0.00 cusr  0.01 csys =  0.94 CPU)
Result: PASS
arrayOpTest.tap ........ ok
analogMonitorTest.tap .. ok
scanEventTest.tap ...... ok
../configure/RULES_DIRS:84: recipe for target 'std/rec/test.test-results' failed
make[1]: *** [std/rec/test.test-results] Error 2
make[1]: Target 'test-results' not remade because of errors.
configure/RULES_DIRS:84: recipe for target 'src.test-results' failed
make: *** [src.test-results] Error 2
make: Target 'test-results' not remade because of errors.
Build step 'Execute shell' marked build as failure
TAP Reports Processing: START
Looking for TAP results report in workspace using pattern: src/**/O.linux-x86/*.tap
Saving reports...
Not all test cases were executed according to the test set plan. Marking build as UNSTABLE
TAP Reports Processing: FINISH
Jenkins build is unstable: epics-base-3.15-linux32-test #257 APS Jenkins via Core-talk
Prev: Build failed in Jenkins: epics-base-3.15-mac-test #283 APS Jenkins via Core-talk
Next: Jenkins build became unstable: epics-base-3.15-win32-test #274 APS Jenkins via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <2020>  2021  2022  2023  2024  2025  2026
Prev: Jenkins build is back to stable : epics-base-3.15-mac-test #285 APS Jenkins via Core-talk
Next: Jenkins build is unstable: epics-base-3.15-linux32-test #257 APS Jenkins via Core-talk
ANJ, 18 Feb 2020 · Home · News · About · Talk · Base · Modules · Extensions ·
