2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <2020>  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <2020>  2021  2022  2023  2024  2025  2026
Subject: [Bug 1842661] Re: seq record doesn't process LNK0 in "Specified" mode
From: Gabriel Fedel via Core-talk <core-talk at aps.anl.gov>
To: core-talk at aps.anl.gov
Date: Tue, 18 Feb 2020 09:29:39 -0000
Solved for base 7.0 by this commit https://github.com/epics-base/epics-
base/commit/90c0f5c48d133cfd0b394cd724eddbca6ff41a1b
The problem happens on 3.15 also.
You received this bug notification because you are a member of EPICS
Core Developers, which is subscribed to EPICS Base.
Matching subscriptions: epics-core-list-subscription
https://bugs.launchpad.net/bugs/1842661
Title:
Status in EPICS Base:
  In Progress
Bug description:
  While updating the seq record reference documentation, we noticed that
  if one tries to use a seq record in "Specified" mode, the LNK0 will
  never be processed, regardless of the OFFS field.
  Possible cause in src/std/rec/seqRecord.c:
          if (prec->selm == seqSELM_Specified) {
              int grpn = prec->seln + prec->offs;
              if (grpn < 0 || grpn >= NUM_LINKS) {
                  recGblSetSevr(prec, SOFT_ALARM, INVALID_ALARM);
                  return asyncFinish(prec);
              if (grpn == 0)
              lmask = 1 << grpn;
  (code from branch 3.15)
To manage notifications about this bug go to:
https://bugs.launchpad.net/epics-base/+bug/1842661/+subscriptions
Prev: Build failed: EPICS Base base-7.0-545 AppVeyor via Core-talk
Next: [Bug 1829770] Re: event record device support broken with constant INP Gabriel Fedel via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <2020>  2021  2022  2023  2024  2025  2026
Prev: [Bug 1842661] Re: seq record doesn't process LNK0 in "Specified" mode Gabriel Fedel via Core-talk
Next: Build failed: EPICS Base base-7.0-525 AppVeyor via Core-talk
ANJ, 18 Feb 2020 · Home · News · About · Talk · Base · Modules · Extensions ·
