2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <2020>  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <2020>  2021  2022  2023  2024  2025  2026
Subject: RE: Setting up AppVeyor builds
From: Freddie Akeroyd - UKRI STFC via Core-talk <core-talk at aps.anl.gov>
To: "EPICS core-talk (core-talk at aps.anl.gov)" <core-talk at aps.anl.gov>
Date: Thu, 20 Feb 2020 21:09:47 +0000
Hi Martin,
I think you may need to update the ci scripts on the 3-15 branch to mirror those on the 7.0 branch https://github.com/epics-base/epics-base/tree/7.0/.ci -  a few issues were fixed there, which may be related
Freddie
-----Original Message-----
Sent: 20 February 2020 21:09
To: 'Michael Davidsaver' <mdavidsaver at gmail.com>; Konrad, Martin <konrad at frib.msu.edu>
Hi Martin,
Freddie
From: Core-talk <core-talk-bounces at aps.anl.gov> On Behalf Of Michael Davidsaver via Core-talk
Sent: 20 February 2020 21:02
To: Konrad, Martin <konrad at frib.msu.edu>
Cc: core-talk at aps.anl.gov
Subject: Re: Setting up AppVeyor builds
I had no idea that appveyor would build from a launchpad.net repo.
I've always pushed again to github.com.  This doesn't require any special config.
On 2/20/20 12:54 PM, Konrad, Martin via Core-talk wrote:
> Hi Ralph,
> I tried to set up AppVeyor to build a branch from my personal
> epics-base Git repo on Launchpad. But so far I failed miserably...
> Here is what I tried: I created a new project pointed it to
> https://git.launchpad.net/~info-martin-konrad/epics-base realizing
> that many things do not seem to get configured automatically (not sure
> if they should). So I manually started tweaking a few things:
> Default branch: fix-log-issues
> Branches to build: Only branches specified below fix-log-issues [X] Do
> not build tags
> Install script: Cmd
> ci/appveyor-prepare.bat
> Build script: Cmd
> ci/appveyor-make.bat
> So far no luck, it fails with "Installation for MSVC Toolchain / 64BIT
> seems to be missing" [1].
> Am I missing something?
> Thanks,
> Martin
> [1]
> https://ci.appveyor.com/project/MartinKonrad/epics-base/builds/3094856
> 4
Setting up AppVeyor builds Konrad, Martin via Core-talk
Re: Setting up AppVeyor builds Michael Davidsaver via Core-talk
Prev: Re: Setting up AppVeyor builds Michael Davidsaver via Core-talk
Next: Build failed: epics-base base-7.0-1 AppVeyor via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <2020>  2021  2022  2023  2024  2025  2026
ANJ, 20 Feb 2020 · Home · News · About · Talk · Base · Modules · Extensions ·
