2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <2020>  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <2020>  2021  2022  2023  2024  2025  2026
Subject: Re: write to a single element of an array field
From: Ben Franksen via Core-talk <core-talk at aps.anl.gov>
To: Ralph Lange <ralph.lange at gmx.de>, EPICS Core Talk <core-talk at aps.anl.gov>
Date: Wed, 18 Mar 2020 18:53:31 +0100
Am 18.03.20 um 18:15 schrieb Ralph Lange via Core-talk:
> Oh, you're thinking "scalar to array" for this whole thing?
> I was always assuming "array to array".
Well, EPICS traditionally makes no distinction between arrays and
scalars: scalars are just arrays with one element. This is the case at
the level of record field definition and also in CA. (This is different
for pvData but we are talking about the IOC core which is still based on
the old type model.)
To answer your question, no, I did not *exclusively* think "scalar to
array". I merely used it as the simplest (and most convincing) example.
The argument is quite similar for "array to array":
  caput -a PV.[2:2:6] 3 1.0 2.0 3.0
has (IMHO) only one sensible interpretation namely "write 1.0 to PV[2],
2.0 to PV[4], and 3.0 to PV[6]".
Similarly,
record(wf,"X") {
  field(OUT,"PV.[2:2:6]")
should mean "write the first 3 elements of X.VAL to PV[2], pv[4], and
PV[6], respectively". If X.VAL has less elements (X.NORD < 3) then of
course only up to NORD elements are written.
The reason I make these assertions is that the "configuration" is
attached to the name of the target PV. IMO this makes it untuitively
clear that the target PV is what the configuration refers to, at least
by default.
Cheers
Ben
Aufsichtsrat: Vorsitzender Dr. Volkmar Dietz, stv. Vorsitzende Dr. Jutta Koch-Unterseher
Geschäftsführung: Prof. Dr. Bernd Rech (Sprecher), Prof. Dr. Jan Lüning, Thomas Frederking
Postadresse:
Hahn-Meitner-Platz 1
D-14109 Berlin
Attachment: pEpkey.asc
Description: application/pgp-keys
Re: write to a single element of an array field Ben Franksen via Core-talk
Re: write to a single element of an array field Ralph Lange via Core-talk
Prev: Jenkins build is still unstable: epics-base-7.0-win64s-test #146 APS Jenkins via Core-talk
Next: IOC build fails after removing an iocBoot dir from Git Konrad, Martin via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <2020>  2021  2022  2023  2024  2025  2026
Prev: Re: write to a single element of an array field Ralph Lange via Core-talk
Next: Re: write to a single element of an array field Zimoch Dirk (PSI) via Core-talk
ANJ, 19 Mar 2020 · Home · News · About · Talk · Base · Modules · Extensions ·
