2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <2020>  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <2020>  2021  2022  2023  2024  2025  2026
Subject: Re: write to a single element of an array field
From: Ben Franksen via Core-talk <core-talk at aps.anl.gov>
To: EPICS Core Talk <core-talk at aps.anl.gov>
Date: Sun, 22 Mar 2020 09:47:09 +0100
Okay, I think I finally begin to understand why things are as they are.
My refactor proposals were ill-informed and won't work. The meta data
stored inside a db_field_log are a (much) simplified and stripped down
version of the set of all possible meta data that can accompany a field
value, such as specified via the options parameter given to dbGet. To
get at some of these meta data, calls to record support methods are
required. This means we always need a full dbAddr, even if the
db_field_log type is not dbfl_type_rec.
Cheers
Ben
Aufsichtsrat: Vorsitzender Dr. Volkmar Dietz, stv. Vorsitzende Dr. Jutta Koch-Unterseher
Geschäftsführung: Prof. Dr. Bernd Rech (Sprecher), Prof. Dr. Jan Lüning, Thomas Frederking
Postadresse:
Hahn-Meitner-Platz 1
D-14109 Berlin
Attachment: pEpkey.asc
Description: application/pgp-keys
Re: write to a single element of an array field Ben Franksen via Core-talk
Re: write to a single element of an array field Ralph Lange via Core-talk
Re: write to a single element of an array field Johnson, Andrew N. via Core-talk
Prev: RE: C++ question Mark Rivers via Core-talk
Next: Re: write to a single element of an array field Ben Franksen via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <2020>  2021  2022  2023  2024  2025  2026
Prev: Re: write to a single element of an array field Ben Franksen via Core-talk
ANJ, 22 Mar 2020 · Home · News · About · Talk · Base · Modules · Extensions ·
