2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <2020>  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <2020>  2021  2022  2023  2024  2025  2026
Subject: Re: Error (511,511)
From: Mark Rivers via Core-talk <core-talk at aps.anl.gov>
To: Michael Davidsaver <mdavidsaver at gmail.com>
Cc: EPICS core-talk <core-talk at aps.anl.gov>
Date: Sun, 22 Mar 2020 16:18:38 +0000
Hi Michael,
> recGblRecordError() isn't often used.  The unique part is the trailing "ReadOut".
ReadOut is the second enum choice in this record, which is a GenICam feature of that camera.
record(mbbo, "$(P)$(R)GC_TriggerOverlap") {
  field(DTYP, "asynInt32")
  field(OUT,  "@asyn($(PORT),$(ADDR=0),$(TIMEOUT=1))GC_E_TriggerOverlap")
  field(DOL,  "0")
  field(ZRST, "Off")
  field(ZRVL, "0")
  field(ONST, "ReadOut")
  field(ONVL, "1")
  field(DISA, "0")
My client is writing the string "ReadOut" to that PV.  It works fine when the frame rate is less than 100 frames/s.
Something is going wrong for this record at higher frame rates.  But acquisition is supposed to have stopped when the client writes to that PV, so the frame rate should not matter.  Adding 0.1 delay in the client before writing that value does not seem to help.
I'll try to figure out where  recGblRecordError() is being called.
From: Michael Davidsaver <mdavidsaver at gmail.com>
Sent: Sunday, March 22, 2020 10:59 AM
To: Mark Rivers
Cc: EPICS core-talk
On 3/22/20 8:53 AM, Mark Rivers wrote:
> Hi Michael,
> Before I got your message I got as far as figuring out that the message was from this line in errSymLib.c::errRawCopy.
> epicsSnprintf(pBuf, bufLength, "Error (%u,%u)", modnum, errnum);
> And this line in errMdef.h defines 511 to be the module Database access:
> #define M_dbAccess      (511 << 16) /* Database Access Routines */
> How did you determine that it is recGblRecordError, and how do I track it down?
The string "PV: " doesn't appear in Base nearly as often as you might think.
> It is not an error I ever recall seeing before.
That's not in Base.
> Thanks,
> Mark
> ________________________________
> From: Core-talk <core-talk-bounces at aps.anl.gov> on behalf of Michael Davidsaver via Core-talk <core-talk at aps.anl.gov>
> Sent: Sunday, March 22, 2020 10:44 AM
> To: core-talk at aps.anl.gov
> On 3/22/20 8:42 AM, Michael Davidsaver wrote:
>> On 3/22/20 8:37 AM, Mark Rivers via Core-talk wrote:
>>> Error (511,511) PV: 13BMDPG1:cam1:TriggerOverlap ReadOut
>> Looks like recGblDbaddrError() in Base 7.0.  Maybe called with status==-1 ?
> Make that recGblRecordError(), I copied the wrong name...
Error (511,511) Mark Rivers via Core-talk
Re: Error (511,511) Michael Davidsaver via Core-talk
Prev: Re: Error (511,511) Michael Davidsaver via Core-talk
Next: [Bug 1868486] [NEW] epicsMessageQueue lost messages mdavidsaver via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <2020>  2021  2022  2023  2024  2025  2026
Next: RE: Error (511,511) Mark Rivers via Core-talk
ANJ, 22 Mar 2020 · Home · News · About · Talk · Base · Modules · Extensions ·
