2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <2020>  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <2020>  2021  2022  2023  2024  2025  2026
Subject: [Bug 1868486] Re: epicsMessageQueue lost messages
From: mdavidsaver via Core-talk <core-talk at aps.anl.gov>
To: core-talk at aps.anl.gov
Date: Sun, 22 Mar 2020 17:32:52 -0000
I'm not planning to take the time to fix this issue.
Given that this is such a long standing issue, another course of action
would be to remove/deprecate the *WithTimeout() variants for send and
receive?  Maybe leaving stubs which ignore the timeout?
You received this bug notification because you are a member of EPICS
Core Developers, which is subscribed to EPICS Base.
Matching subscriptions: epics-core-list-subscription
https://bugs.launchpad.net/bugs/1868486
Title:
Status in EPICS Base:
  Confirmed
Bug description:
  https://epics.anl.gov/core-talk/2020/msg00396.php
  Mark Rivers observed epicsMessageQueue losing messages.
  https://epics.anl.gov/core-talk/2020/msg00408.php
  > I think I see the logic error in how the eventSent flag is handled,
  > specifically related to the fact that epicsEvent is a semaphore as
  > opposed to a condition variable.
  > This allows a "race" to occur if the first/only waiting receiver
  > times out, and epicsEventWaitWithTimeout() returns, while a sender
  > is in epicsMessageQueueSend() preparing to wake up a receiver.
  > This results in a situation where the sender has set the eventSent,
  > and indeed copied a message to the buffer of, a thread which has
  > decided to abort.
  > After timing out, the receiver sees the timeout and returns -1
  > even through eventSent has been set.  This can be trapped with:
  > > b osdMessageQueue.cpp:358 if status!=0 && threadNode.eventSent
  > So here is your lost message.
  > Now when epicsMessageQueueReceiveWithTimeout() is called again, no message
  > is waiting in the queue, so epicsEventWaitWithTimeout() is called.
  > Since the semaphore is already set, this returns immediately with status==0,
  > but this is a spurious wakeup and the eventSent flag is not set.
  > And here is the second "timeout".
  Line numbers circa 7.0.3.1
To manage notifications about this bug go to:
https://bugs.launchpad.net/epics-base/+bug/1868486/+subscriptions
[Bug 1868486] [NEW] epicsMessageQueue lost messages mdavidsaver via Core-talk
Prev: [Bug 1868486] Re: epicsMessageQueue lost messages mdavidsaver via Core-talk
Next: Re: C++ question (Bug in epicsMessageQueue) Michael Davidsaver via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <2020>  2021  2022  2023  2024  2025  2026
Next: [Bug 1868486] Re: epicsMessageQueue lost messages rivers via Core-talk
ANJ, 23 Mar 2020 · Home · News · About · Talk · Base · Modules · Extensions ·
