2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <2020>  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <2020>  2021  2022  2023  2024  2025  2026
Subject: Re: [Merge] ~dirk.zimoch/epics-base:dbChannelForDBLinks into epics-base:7.0
From: Dirk Zimoch via Core-talk <core-talk at aps.anl.gov>
To: mp+378968 at code.launchpad.net
Date: Thu, 26 Mar 2020 16:56:11 -0000
I have re-structured the code a bit to make it less confusing. Also debug output is in. Tell me if you like it, then I will push it (without the debug code).
static long dbDbGetValue(struct link *plink, short dbrType, void *pbuffer,
        long *pnRequest)
    struct pv_link *ppv_link = &plink->value.pv_link;
    dbChannel *chan = linkChannel(plink);
    DBADDR *paddr = &chan->addr;
    dbCommon *precord = plink->precord;
    db_field_log *pfl = NULL;
    long status;
    struct timespec start, stop;
    int path;
    /* scan passive records if link is process passive  */
    if (ppv_link->pvlMask & pvlOptPP) {
        status = dbScanPassive(precord, dbChannelRecord(chan));
        if (status)
            return status;
    clock_gettime(CLOCK_MONOTONIC, &start);
    if (ppv_link->getCvt && ppv_link->lastGetdbrType == dbrType)
        /* shortcut: scalar with known conversion, no filter */
        status = ppv_link->getCvt(dbChannelField(chan), pbuffer, paddr);
        path = 1;
    else if (dbChannelFinalElements(chan) == 1 && (!pnRequest || *pnRequest == 1)
                && dbChannelSpecial(chan) != SPC_DBADDR
                && dbChannelSpecial(chan) != SPC_ATTRIBUTE
                && ellCount(&chan->filters) == 0)
        /* simple scalar: set up shortcut */
        unsigned short dbfType = dbChannelFinalFieldType(chan);
        if (dbrType < 0 || dbrType > DBR_ENUM || dbfType > DBF_DEVICE)
            return S_db_badDbrtype;
        ppv_link->getCvt = dbFastGetConvertRoutine[dbfType][dbrType];
        ppv_link->lastGetdbrType = dbrType;
        path = 2;
    else
        /* filter, array, or special */
        ppv_link->getCvt = NULL;
        /* For the moment, empty arrays are not supported by EPICS */
        if (dbChannelFinalElements(chan) <= 0) /* empty array request */
            return S_db_badField;
        if (ellCount(&chan->filters)) {
            /* If filters are involved in a read, create field log and run filters */
            pfl = db_create_read_log(chan);
            if (!pfl)
                return S_db_noMemory;
            pfl = dbChannelRunPreChain(chan, pfl);
            pfl = dbChannelRunPostChain(chan, pfl);
        status = dbChannelGet(chan, dbrType, pbuffer, NULL, pnRequest, pfl);
        if (pfl)
            db_delete_field_log(pfl);
        if (status)
            return status;
        if (pnRequest && *pnRequest <= 0) /* empty array result */
        path = 3;
    clock_gettime(CLOCK_MONOTONIC, &stop);
    if ((stop.tv_nsec -= start.tv_nsec) < 0) stop.tv_nsec += 1000000000;
    errlogPrintf("dbDbGetValue(%s)[%ld] took %ld ns for %s path with %d filters\n",
        chan->name, dbChannelFinalElements(chan),
        stop.tv_nsec, path==1?"shortcut":path==2?"simple":"full",
        ellCount(&chan->filters));
    if (!status && precord != dbChannelRecord(chan))
        recGblInheritSevr(plink->value.pv_link.pvlMask & pvlOptMsMode,
            plink->precord,
            dbChannelRecord(chan)->stat, dbChannelRecord(chan)->sevr);
    return status;
https://code.launchpad.net/~dirk.zimoch/epics-base/+git/epics-base/+merge/378968
Your team EPICS Core Developers is subscribed to branch epics-base:7.0.
Re: [Merge] ~dirk.zimoch/epics-base:dbChannelForDBLinks into epics-base:7.0 Ben Franksen via Core-talk
[Merge] ~dirk.zimoch/epics-base:dbChannelForDBLinks into epics-base:7.0 Dirk Zimoch via Core-talk
Prev: Re: [Merge] ~dirk.zimoch/epics-base:dbChannelForDBLinks into epics-base:7.0 Dirk Zimoch via Core-talk
Next: Re: [Merge] ~dirk.zimoch/epics-base:dbChannelForDBLinks into epics-base:7.0 Ben Franksen via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <2020>  2021  2022  2023  2024  2025  2026
Prev: Re: [Merge] ~dirk.zimoch/epics-base:dbChannelForDBLinks into epics-base:7.0 Ben Franksen via Core-talk
ANJ, 26 Mar 2020 · Home · News · About · Talk · Base · Modules · Extensions ·
