2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <2020>  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <2020>  2021  2022  2023  2024  2025  2026
Subject: Re: [Merge] ~bfrk/epics-base:zero-size-array-request into epics-base:7.0
From: mdavidsaver via Core-talk <core-talk at aps.anl.gov>
To: mp+381308 at code.launchpad.net
Date: Mon, 30 Mar 2020 16:21:23 -0000
Given that changing db_post_events() to use field indices would be fairly painful, the only alternative I can think of would be to add a new member of struct dbAddr to hold the original field pointer.
https://code.launchpad.net/~bfrk/epics-base/+git/epics-base/+merge/381308
Your team EPICS Core Developers is requested to review the proposed merge of ~bfrk/epics-base:zero-size-array-request into epics-base:7.0.
[Merge] ~bfrk/epics-base:zero-size-array-request into epics-base:7.0 Ben Franksen via Core-talk
Prev: Re: [Merge] ~bfrk/epics-base:zero-size-array-request into epics-base:7.0 mdavidsaver via Core-talk
Next: Re: [Merge] ~bfrk/epics-base:zero-size-array-request into epics-base:7.0 Ben Franksen via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <2020>  2021  2022  2023  2024  2025  2026
ANJ, 30 Mar 2020 · Home · News · About · Talk · Base · Modules · Extensions ·
