2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <2020>  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <2020>  2021  2022  2023  2024  2025  2026
Subject: Re: [Merge] ~bfrk/epics-base:zero-size-array-request into epics-base:7.0
From: Ben Franksen via Core-talk <core-talk at aps.anl.gov>
To: mdavidsaver <mdavidsaver at gmail.com>
Date: Wed, 01 Apr 2020 08:00:55 -0000
Am 01.04.20 um 07:15 schrieb mdavidsaver:
>> I understand your second remark to refer to an API change ...
> As one of two possibilities.  I prefer the other.  eg.
> https://github.com/mdavidsaver/epics-base/pull/new/dbAddrCompare
I don't. Using pfield as an identifier is a horrible kludge, and your
dbAddrCompare merely puts veneer on the ugliness, making it even harder
to eventually get rid of it.
> but we're drifting off topic here.
Very much ;-)
https://code.launchpad.net/~bfrk/epics-base/+git/epics-base/+merge/381308
Your team EPICS Core Developers is requested to review the proposed merge of ~bfrk/epics-base:zero-size-array-request into epics-base:7.0.
Re: [Merge] ~bfrk/epics-base:zero-size-array-request into epics-base:7.0 mdavidsaver via Core-talk
Prev: Re: [Merge] ~bfrk/epics-base:zero-size-array-request into epics-base:7.0 mdavidsaver via Core-talk
Next: Re: [Merge] ~bfrk/epics-base:remove-dbfl_type_rec into epics-base:7.0 Ben Franksen via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <2020>  2021  2022  2023  2024  2025  2026
Next: Lessons learned investigating EPICS Base build failures Ralph Lange via Core-talk
ANJ, 01 Apr 2020 · Home · News · About · Talk · Base · Modules · Extensions ·
