2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <2020>  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <2020>  2021  2022  2023  2024  2025  2026
Subject: Re: [Merge] ~bfrk/epics-base:remove-dbfl_type_rec into epics-base:7.0
From: Ben Franksen via Core-talk <core-talk at aps.anl.gov>
To: mp+381464 at code.launchpad.net
Date: Wed, 01 Apr 2020 09:00:52 -0000
I removed the patch that changes the dbGetField API and added a new commit to address the point about "If the dtor is NULL, then this means the array data is still owned by a record".
The conflict is still there, pending a recommendation how to set up my branch properly.
https://code.launchpad.net/~bfrk/epics-base/+git/epics-base/+merge/381464
Your team EPICS Core Developers is requested to review the proposed merge of ~bfrk/epics-base:remove-dbfl_type_rec into epics-base:7.0.
[Merge] ~bfrk/epics-base:remove-dbfl_type_rec into epics-base:7.0 Ben Franksen via Core-talk
Prev: Re: [Merge] ~bfrk/epics-base:remove-dbfl_type_rec into epics-base:7.0 Ben Franksen via Core-talk
Next: Graceful Shutdown with joinable thread Kim, Kukhee via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <2020>  2021  2022  2023  2024  2025  2026
Next: Re: [Merge] ~bfrk/epics-base:remove-dbfl_type_rec into epics-base:7.0 Ben Franksen via Core-talk
ANJ, 03 Apr 2020 · Home · News · About · Talk · Base · Modules · Extensions ·
