2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <2020>  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <2020>  2021  2022  2023  2024  2025  2026
Subject: Re: [Merge] ~bfrk/epics-base:remove-dbfl_type_rec into epics-base:7.0
From: Ben Franksen via Core-talk <core-talk at aps.anl.gov>
To: mp+381464 at code.launchpad.net
Date: Fri, 03 Apr 2020 07:33:26 -0000
Since no-one came forward with a recommendation, I have now locally rebased all my changes such that they cleanly apply on branch 7.0. I did this by creating a new branch that forks off at the current HEAD of 7.0, then merging Dirk's branch dbChannelForDBLinks into that, and then replaying my changes, resolving the single conflict in the array filter implementation.
I have pushed this 'work' branch to my launchpad fork of epics base. All tests pass on all my intermediate versions.
Before I force-push the other branch refs (which are now on the work branch) to my fork (thereby updating all my merge requests), can somebody please tell me if this is what I should do?
https://code.launchpad.net/~bfrk/epics-base/+git/epics-base/+merge/381464
Your team EPICS Core Developers is requested to review the proposed merge of ~bfrk/epics-base:remove-dbfl_type_rec into epics-base:7.0.
[Merge] ~bfrk/epics-base:remove-dbfl_type_rec into epics-base:7.0 Ben Franksen via Core-talk
Prev: Jenkins build is back to stable : epics-base-3.15-win64-test #294 APS Jenkins via Core-talk
Next: [Merge] ~bfrk/epics-base:address-modifiers into epics-base:7.0 Ben Franksen via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <2020>  2021  2022  2023  2024  2025  2026
Prev: Re: [Merge] ~bfrk/epics-base:remove-dbfl_type_rec into epics-base:7.0 Ben Franksen via Core-talk
Next: Re: [Merge] ~bfrk/epics-base:remove-dbfl_type_rec into epics-base:7.0 Ben Franksen via Core-talk
ANJ, 03 Apr 2020 · Home · News · About · Talk · Base · Modules · Extensions ·
