2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <2020>  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <2020>  2021  2022  2023  2024  2025  2026
Subject: MSVC printf/vararg weirdness
From: Michael Davidsaver via Core-talk <core-talk at aps.anl.gov>
To: EPICS core-talk <core-talk at aps.anl.gov>
Date: Mon, 13 Apr 2020 00:29:20 -0700
All,
I've run up against a strange behavior with MSVC.  I've reduced the problem somewhat,
but which I'm not sure how to proceed.  This might have something to do with the
MSVC pre-processor, implicit concatenation of string constants, or maybe vararg functions.
It has to do with how I'm trying to do logging.  At core I have a function:
> void _log_printf(unsigned lvl, const char* fmt, ...);
which internally calls errlogVprintf()
I'm calling it through two levels of macro.  eg.
> #define log_info_printf(LOGGER, ...)  log_printf(LOGGER, ::pvxs::Level::Info, __VA_ARGS__)
> #define log_printf(LOGGER, LVL, FMT, ...) do{ \
>     if((LOGGER).test(LVL)) \
>        ::pvxs::detail:: _log_printf(unsigned(LVL), "%s " FMT, "", __VA_ARGS__); \
> }while(0)
called like:
> log_info_printf(logerr, "Enter loop worker for %p\n", base.get());
The reason for the second level of macro is that I'd like to prefix each log line
with some extra information, including a timestamp, in a way which can't be split.
(as could happen if I called errlogPrintf() twice)
The above is already a reduced case.  The empty string constant "" after FMT will be
replaced with a char* returned by a function (a thread local buffer).  However, I can't
get that far.
The above, with the empty string constant, is somehow corrupting output and crashing.
eg.
> `b"l� Enter loop worker for 00007FFA6C34DCC0
If I change the log_printf macro as follows, then everything is fine (sans timestamp).
>        ::pvxs::detail:: _log_printf(unsigned(LVL), FMT, __VA_ARGS__); \
> }while(0)
Does anyone have an idea of what is going on here?
I don't think I'm depending on any GCC-isms here.  (eg.  __VA_ARGS__ always has
at least one argument)  And '"%s " FMT' should be taking advantage of automatic
concatenation of string constants.
I'm seeing this on appveyor with the MSVC 2019, 2017, and 2015.
mingw builds work fine.
https://ci.appveyor.com/project/mdavidsaver/pvxs
the full version I'm starting from (and would like to end with).
https://github.com/mdavidsaver/pvxs/blob/e2a7e5e451a06e3865b8684e747dfaa6026a6e15/src/pvxs/log.h#L77-L80
RE: MSVC printf/vararg weirdness Freddie Akeroyd - UKRI STFC via Core-talk
Prev: merge requests for dbChannelForDBLinks et al. Michael Davidsaver via Core-talk
Next: [Bug 1868486] Re: epicsMessageQueue lost messages rivers via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <2020>  2021  2022  2023  2024  2025  2026
Prev: Re: merge requests for dbChannelForDBLinks et al. Ben Franksen via Core-talk
Next: RE: MSVC printf/vararg weirdness Freddie Akeroyd - UKRI STFC via Core-talk
ANJ, 14 Apr 2020 · Home · News · About · Talk · Base · Modules · Extensions ·
