2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <2020>  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <2020>  2021  2022  2023  2024  2025  2026
Subject: Re: [Merge] ~bfrk/epics-base:scalar-get-optimization into epics-base:7.0
From: Ben Franksen via Core-talk <core-talk at aps.anl.gov>
To: mp+382204 at code.launchpad.net
Date: Tue, 14 Apr 2020 11:12:52 -0000
Review: Approve
I have re-submitted with an updated dependency. The type signature of dbGetField is unchanged. the change in the type signature for dbChannelGet merely makes the type of the last parameter more strongly typed. If some client passed something that is not a db_field_log* it would be an error.
Dirk has shown with a simple benchmark that the optimization is worthwhile for DB links, as Andrew had previously suspected. See the diuscussion starting at https://code.launchpad.net/~dirk.zimoch/epics-base/+git/epics-base/+merge/378968/comments/1000328
I deliberately did not move it to dbGet because dbGet with its multiple case distinctions is already quite a complicated beast. Entangling the optimization with that code would have been counter-productive. My goal was to disentangle it and put it in a single place, which is precisely why I chose dbChannelGet which, as you observed, was previously just a simple wrapper for dbGet.
https://code.launchpad.net/~bfrk/epics-base/+git/epics-base/+merge/382204
Your team EPICS Core Developers is requested to review the proposed merge of ~bfrk/epics-base:scalar-get-optimization into epics-base:7.0.
[Merge] ~bfrk/epics-base:scalar-get-optimization into epics-base:7.0 Ben Franksen via Core-talk
Prev: [Merge] ~bfrk/epics-base:scalar-get-optimization into epics-base:7.0 Ben Franksen via Core-talk
Next: [Bug 1861612] Re: callbackRequestDelay not waiting for 1/60 sec on vxWorks Ben Franksen via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <2020>  2021  2022  2023  2024  2025  2026
Next: [Merge] ~bfrk/epics-base:zero-size-array-request into epics-base:7.0 Ben Franksen via Core-talk
ANJ, 14 Apr 2020 · Home · News · About · Talk · Base · Modules · Extensions ·
