2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <2020>  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <2020>  2021  2022  2023  2024  2025  2026
Subject: Re: AppVeyor issue
From: Michael Davidsaver via Core-talk <core-talk at aps.anl.gov>
To: Ralph Lange <ralph.lange at gmx.de>
Cc: EPICS Core Talk <core-talk at aps.anl.gov>
Date: Tue, 14 Apr 2020 09:43:37 -0700
On 4/14/20 9:21 AM, Ralph Lange via Core-talk wrote:
> On Mon, 13 Apr 2020 at 20:28, Michael Davidsaver via Core-talk <core-talk at aps.anl.gov <mailto:core-talk at aps.anl.gov>> wrote:
>     On 4/13/20 11:21 AM, Konrad, Martin wrote:
>     > I'm wondering if AppVeyor has any caches I could purge?
>     It does (I think) though the epics-base config have never used them.
> AppVeyor cache limit is 1GB per account (across all projects, branches, builds, and jobs) - and builds fail if the cache is full.
> Pretty much unusable.
Ouch.  The per-account part really stings.  And the limit doesn't go away even with the expensive tier.
https://www.appveyor.com/docs/build-cache/#cache-size-beta
For reference, the total cache for the PVXS repo on travis-ci is ~11GB.
That's just Base, no other dependencies.  I suspect much of that
is object files though.
> The up-to-date AppVeyor support (Freddies's idea - thanks!) uses it for the downloaded tools: perl, make etc.
> Cheers,
> ~Ralph
Attachment: signature.asc
Description: OpenPGP digital signature
AppVeyor issue Konrad, Martin via Core-talk
Re: AppVeyor issue Konrad, Martin via Core-talk
Re: AppVeyor issue Michael Davidsaver via Core-talk
Re: AppVeyor issue Ralph Lange via Core-talk
Prev: Re: AppVeyor issue Ralph Lange via Core-talk
Next: Re: AppVeyor issue Johnson, Andrew N. via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <2020>  2021  2022  2023  2024  2025  2026
Next: [Merge] ~info-martin-konrad/epics-base:explicitly-specify-appveyor-worker-image into epics-base:3.15 Martin Konrad via Core-talk
ANJ, 14 Apr 2020 · Home · News · About · Talk · Base · Modules · Extensions ·
